Let the hacking begin... (Model S parts on the bench)
Discussion in 'Model S' started by wk057, Dec 14, 2015.
Tags:
  1. garygid
    garygid Member
    Laguna Hills, Orange County, CA
    #101 garygid, Dec 17, 2015
    I wrote a program to capture CAN data, save in log files, and load logs for
    later examination. It allows one to easily graph data from bytes in the messages,
    in an attempt to understand the data. The program is called CAN-DO and is
    a work in progress (in Visual Basic), but a number of serious investigators
    worldwide have used it to examine their CAN data.
    We made a CAN capture card using the AVR-CAN board, passively listening
    to the LEAF's 500k CAN bus on the OBD connector. We wanted to find a value
    for "remaining fuel", which would be more helpful than the "tank fullness"
    data that was displayed in 12 coarse steps on the dash.
    We were successful, and we created an energy meter that was known as
    the SOC-Meter, but more accurately became known as the GID-Meter.
    Eventually it displayed Energy, SoC, pack Voltage, Amps, and Power,
    and tire pressures, all of which were not available on the LEAF's dashboard.
    We could use CAN-DO to investigate the Tesla data. See
    GaryG's CAN-Do Program Page for more info.
    If I had some Tesla logs, preferably in my 12-byte per message
    format, I could do some testing. The 1st 2 bytes contain
    second and millisecond, the next two are the msgid and
    data length, and then 8 data bytes.
    If you are interested, I will provide the exact format of the
    SS MS MM LM D1 ... D8 bytes.
    Oh well, ...
    The time stamp:
    MS is the low 8 bits of the 10-bit milliseconds (0 to 999 values),
    and the two low bits of SS are the two high bits of the milliseconds.
    The top 6 bits of SS are seconds (0 to 59) of the current minute.
    The LMMM two bytes is one nibble (L) for the data length (0 to 8)
    and the remaining 3 nibbles (MMM) for the hex MessageID (usually
    0 through 7FF hex values).
    I use MMM 800 to FFF and L > 8 for some special uses
    in the log file, like a date-time message at the zero second,
    zero millisecond point (so, once a minute, helpful, but optional).
    Merry Christmas to all, wishing for a miracle of communication,
    understanding, sharing, and peace worldwide. What is the
    alternative, just continued war, and perhaps extinction.
  2. garygid
    garygid Member
    If you wish to try CAN-DO, you are welcome to do so as long as
    you are willing to share your results with the rest of us.
    Download it along with a log file or two,
    and a Recipe file, which holds the decoding details for
    discovered or suspected one-byte or two-byte data.
    Sharing Recipe files allow others to easily graph data
    values that have been discovered.
    There are at least 6 sources of CAN type data in the Tesla.
    Perhaps someone can post pictures of their access points,
    give a link to compatible connectors, and specify the details
    of each pin in the connector?
    Also, a description of the type of data found on the connection,
    along with a list of MsgIDs and data byte locations (D1 - D8)
    that have been identified, or are suspected.
    If you can send me some logs, please Message me.
  3. smac
    smac Active Member
    Nottinghamshire
    I'm all up for a project like this!
    Never done any CAN stuff, though I certainly have done reverse engineering of wire protocols, and more than happy to help with front end viewing or statistical analysis.
  4. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    Game over.
    Please do not ask me how to do this just yet... while Tesla isn't patching my bench setup, I'm sure they'll patch cars in an OTA if I released how to do it publicly.
  5. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Sweet job wk! I knew it was only a matter of time before you got into the diagnostics system. I look forward to seeing what else you find in there.
  6. _TTT_
    _TTT_ Member
    US
    Oh now THIS is awesome! Can't wait to see what you find in there....
  7. wk057
    Hickory, NC, USA
    Worth noting this is a dismantle-the-car exploit...... so not super useful for non-bench stuff. I'm not taking my car apart to do this on my own vehicles... lol. But I can play CAN data to my bench and let it decode it for me. :)
  8. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Wow.
    "Achievement Unlocked!"
  9. Andyw2100
    Andyw2100 Well-Known Member
    Ithaca, NY
    And I believe you made this discovery on the eve of the one-year anniversary of the date your car reached the service center. (I remember this because I briefly thought our P85Ds may have been on the same truck. They weren't, though they did reach their respective service centers on the same day--Friday, December 19, 2014.)
    Congratulations!
  10. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    You Sir, Have won the Internet.
    Just be aware, that Tesla does now have a fleet of vehicles that "Could" autonomously drive. You won't hear them knock, but they will silently sneak up and get you when your sleeping.
    - - - Updated - - -
    Would have been awesome if the battery was full to 100% and recorded the info before the accident. I'd like to see what Voltage Limit Tesla is putting on the cells (or in other words, what they call "FULL". Or on the other end of the spectrum, what they consider "Empty". Seems that pack was a bit out of balance before the pull.
  11. wk057
    Hickory, NC, USA
    Oh, I'm going to figure all of that out now. Only a matter of time. :)
  12. Andyw2100
    Ithaca, NY
    I wonder if Tesla is going to regret backing out on their deal to sell you the new 90 pack and let you keep your 85. (Right or wrong, they're probably going to assume that if they had just gone through with the deal, you wouldn't have found this stuff to play with.)
  13. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    You, Sir, are doing amazing work.
  14. FlasherZ
    *pictures Jason locking himself in the test bench room and not emerging for ... at least a few days ...*
  15. mwulff
    mwulff Member
    Danmark
    Awesome. That is some cool work right there. I think many owners would like to monitor our vehicles more closely and access to the diagnostic screen would be great to have.
  16. darthy001
    darthy001 Love my car, hope Tesla can get as great!
    Bærum, Norway
    wow, I've been "fearing" that I already had a somewhat disturbing/geeky man-crush in the making towards you before this thread, but now there exists no doubt anymore. You are my new Tesla Sith Lord :love:
    The force is strong with this one!
    PS! Sorry for the maybe lame SW-references, but its way to easy these days with "The force awakens"-euphoria:)
  17. tom66
    tom66 Member
    United Kingdom
    Yep...you win.
    Can you see a kWh figure anywhere showing remaining capacity?
    Maybe that "mythical" reset button for the range estimation that Tesla SCs will use when selling CPOs?
  18. kennybobby
    kennybobby Member
    Heart o' Dixie
    i wonder what the yellow and green blocks indicate on the Cell voltage readings from the BMB's?
  19. msnow
    msnow Active Member
    SoCal
    Congrats! This is some great stuff right here.
  20. ScepticMatt
    ScepticMatt Member
    Austria
    Well done.
    "You must spread some Reputation around before giving it to wk057 again."
