Chasedrgc1223
Nearly Insane
Go to the enter access code screen and type 'performance'. A new thing comes up, what does it do? Here's the thread, and maybe Jason could tell us some more codes. What does this do? (holding "T")
There are (edit, correction) five line level outputs that I've found and seven amplified outputs. The unit part number says it's a premium audio version. It is pretty likely they're mostly the same though.
It definitely seems to have the last known state of everything cached.
Here is a composite of all of the errors I have now for laughs:
It *really* wants me to contact Tesla service.... lol
Hi,Inverter temp decodes are known. Not sure where I've seen them but they exist.
0x0306
Temperatures are 1C scaling, -40C offset
byte0 = inverter PCB temp
byte1 = inverter temp
byte2 = stator temp
byte3 = DC capactitor temp
byte4 = heat sink temp
byte5 = coolant inlet temp
byte6 = inverter temperatue percentage - 0.4% scaling
byte7 = stator temperature percentage - 0.4% scaling
Hello all!
I'm trying to get some message in canbus related to the values included in the Thermal Management Screen, such as: Passive/Active Coolant Target, Ambient Filtered Temp, etc...
I guess it is in the powertrain (CAN3) but I am not able to get some info about that. Anyone has got some research about that?
Many thanks in advance.
Hello, just signed up to join in on this thread. I've been working on probing the CAN bus for a few weeks now and just last night managed to get my rig so that it would log CAN messages to an SD card. It's an Arduino with a Sparkfun CAN BUS shield. There's only one transceiver on it, so I stuck a DB9 to RJ45 connector on it and wired up the four buses on the diagnostic connector to four separate RJ45 connectors. S60.
I'm still trying to catch up on this thread, only up to page 17 so far...
Have the same rig, but never took the time to try it out. I'm interested in your sketches if you can share
