I was actually thinking whether also copying partition 1 and 2 from The MCU Tegra to IC Tegra would solve the power on problem? Although that is a bit of work. I actually am not sure of the IC pinoutOkay so I've been fiddeling around with the cluster and MCU and found something. The port the MCU uses (4070 because v8.1) is different to the IC (4130 because 2020.48) and thus I get barely any communication between the MCU and cluster. Now I was wondering if I could access the cluster via telnet or something like that and change the port to 4070 because apparantly I am to dumb to actually redeploy and the option to redeploy isn't to be found in the dev menu. Neither can I activate factory mode
Thats a possibility but I'm not trusting myself enough to desolder thr chips and do thatI was actually thinking whether also copying partition 1 and 2 from The MCU Tegra to IC Tegra would solve the power on problem? Although that is a bit of work. I actually am not sure of the IC pinout
in your other post you mentioned that you cannot connect. I am wondering if when you downgraded did you put old verts into the car? I guess thats unlikely but since they do get updated then there could be an issueI managed to downgrade both CID and IC from 2021.24.28 to 2019.36.2.1, reflash the Parrot restoring WiFi and Bluetooth, replaced the 3G with LTE regaining cellular, have SSH, looking pretty good…
But… I’m unable to do any kind of cron or trigger any of my scripts after rebooting without logging in via ssh and triggering them each boot. Cron does not persist. Any advice?
I have the old certs but have not re-added them yet. Will it update without my clicking schedule or do it now? is there a good way of preventing updates?in your other post you mentioned that you cannot connect. I am wondering if when you downgraded did you put old verts into the car? I guess thats unlikely but since they do get updated then there could be an issue
Can you help my with SC? I’m in the Bay Area CAHey @FoxIrate I think I can help with that, send me a dm
How to PM you? my email is kanchi647 at yahoo dot comPm me
yes need to knowCan some give me a hint how to enable developer mode on intel mcu?
