There's no way the motors and inverters are an extra ton. The 6k is probably about right from what I've seen, and the 11k might well be. I suspect Tesla's cab structure will end up being lighter than the others by more than the weight of the motors/inverters, so likely more in the 22k range all up. That will reduce the load capability, but by less than the reduction in cost so it still saves overall if you can package the loads suitably.
I got to thinking about this some more last night.
Why would you think the motors would be light? Maybe they are but you are also doubling them up and you need to transfer that power to the wheels. First of all your transferring several hundred horsepower over long periods of time if you believe Elon's claims, he also claims these units will a million miles without major repairs. Remember he's using motors from a car that uses this kind of power for only seconds at a time and it weighs in at 2800lb (1600lb without batteries) The components required to transfer that kind of power over those periods of time are going to be heavy. Second is you need twice the inverter capacity to transfer twice the power plus do it for long periods of time in extreme conditions, again this is not bursts of power, this is continuous power that needs to be reliable. Also you need to consider attaching these units to the chassis and suspension.
Why are the batteries in crossways? Now you have to build a complex/heavy frame assembly to support the batteries as well as connect the front and rear of the vehicle. Typical frame rails would be far lighter plus they've lost somewhere between a fifty and seventy square feet of potential battery storage. Trucks with conventional powertrains move the engines and related components as far forward as possible, they' actually moved the front axles back to get more weight on the front axles.
A typical unladen highway truck weighs about 10,000lb on the steering axle, in the US they can load to 12,000lb, they accomplish this by moving the fifth wheel forward of the centerline as required so when the tandem drive axles weigh 34,000lb the steering axle will be loaded to legal max weight.
Tesla mounting the batteries midship tells me that battery pack is extremely heavy, it's simple physics.
I'd bet you suspect wrong, most highway truck cab structures are built as light as possible, they've being doing this for a hundred years and most have learned where they can cut corners to lighten trucks up. Aluminum, fiberglass and some composites have been used in the construction of truck cabs for years. Also truck cabs are far simpler than what Tesla appears to be building, Elon stressed creature comforts during his speech. I wouldn't be surprised this unit has motorized doors and other neat gadgets.
The likes of Walmart/J.B. Hunt and others ordering these trucks makes sense in a way as their trucks vary rarely haul max gross weighing loads, their units are designed for maximum cubic capacity, not weight There is also public perception as these companies going "green".
