After 2021.12.25.7 I find that when watching YouTube the LH scroll wheel no longer does anything to the volume. OK on other apps, radio etc. I can't remember this happening before?
Don't know if this is your problem, but I find YouTube volume to be much, much lower than the other sources. You have to really crank it up to hear it. Then, when switching back to another source, the volume is blaring. Are you sure you are not getting any volume?
L learn something new every day!
I've only just found the YouTube app has its own volume slider right at the top - like all the other UI displays no-one has standardised the format. Yes, mine was set to almost zero so the scroll wheel did nothing. Setting the slider to halfway allowed the wheel to adjust volume as it should.
Duh!
Duh!
I wouldn't be surprised to learn many people are unaware - the volume slider is tiny and in a very strange position. Just one more reason why they need to rationalise the UI displays to all be the same.
Yep Same... left scroll moves the volume around without doing anything. It's responsive on the screen just does not change the volume. Hope they fix it quick I use this waaaaay more than I thought!
