Lifetime average power usage starting to go up with heater use!
Discussion in 'Model 3: Battery & Charging' started by timk225, Oct 28, 2018.
  1. timk225
    timk225 Active Member
    Pittsburgh
    I've got 14,400 miles on my 3, and the lifetime power usage meter has been slowly dropping, it was down to 225 Wh/mile recently.
    But now that I'm starting to use the heater, the power usage is going up, it was at 227 yesterday!
    And I already notice the difference, having the heat on in the car sucks the battery down more quickly then using AC.
  2. Rogue one
    Rogue one Member
    Wisconsin
    Yup, well documented that as the temperature goes down the power consumption increases significantly.
  3. TT97
    TT97 Active Member
    Los Angeles
    Easy fix, just migrate to the South for the winter.
    • Funny x 2
  4. timk225
    Pittsburgh
    I'd love to move back to L.A., but I'm married now....:rolleyes:
  5. mswlogo
    mswlogo Well-Known Member
    MA, NH
    What else did you expect?
    Lower regen due to cold battery will kick in too.
    You won’t know your true average until you’ve driven a full year.
  6. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    Do people move to seat heaters or just leave it set on 74° all winter? It seems too luxurious to be able to get heat out of the car as fast as I have been to not use the HVAC. My friends with ICE cars cannot believe how fast it blows hot air.
    -Randy
  7. seattlite2004
    seattlite2004 Active Member
    Puget Sound
    Do the S/X folks that have heated seats AND heated steering wheel still use the cabin heater?
  8. TJtv
    TJtv Member
    NJ
    74? That's uncomfortably warm. Regardless I think the battery heater consumes much more power than the cabin heater(at least on model s/x), so you aren't really saving that much by being stingy with your in car climate.
  9. animorph
    animorph Active Member
    Scottsdale, AZ
    We used the seat heaters a lot in the X last AZ "winter". That should be more energy efficient. But unless you need to conserve range, I'd just use the heater.
  10. eml2
    eml2 Member
    Massachusetts
    How do you turn off the cabin heater? I don't see a cabin heater on/off switch in my MX. There is only a A/C switch.
    Or do you just turn off HVAC? However, without any fresh air circulating, the window may fog up.
  11. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    There's not a button for OFF, but think back to older cars that have the "Three Dials & a Button" climate control. If you want the heater off, just turn the temperature all the way down to LO, but make sure the A/C is off, so it isn't actively trying to chill the interior. Then all it can be doing is blowing the outside air without heating it. But I would not bother going that hardcore in the winter. Just turn it down to 64 or something, and it will run the heat a little, but not as much.
