'Model S 2015 171.000 km
Average 200Wh/km'
Downhill every day, in sunshine, with wind behind you?
Bought a lr raven a few months ago to replace The 75 I posted about earlier. Current wh per mile is 261 vs 268 for the 75. Still breaking in. I hope at around 10,000 miles it will improve like the 75 did. The over the road efficiency is still significantly worse than the 75. I don’t believe the raven range hype. Running at 70-75 the real world efficiency is 84% vs the 75 getting right at 100% of rated range.
No. I cannot "easily go under the rated number" in my car. Of course I can get low consumption going downhill or coasting. But any trip that represents anything like normal driving will consume significantly more than the rated wh/mi. Remember, there is "Ideal Range" and "Rated Range". Ideal range is not achievable with any semblance of normal driving. Rated Range was marketed as readily achievable with modest driving.My LR RWD Model 3 is rated at 325 miles. So 75 kwh battery / 325 miles = 230 Wh.
My lifetime average is 250 Wh.
It's like this for all of the cars. The rating is based on the EPA test cycle, and this isn't unique to Tesla. Gas cars these days are designed for that track, and real life numbers aren't going to match.
That said, you can easily go under the rated number if you stay off the highway. Stop and go city traffic is king for an EV. Or anytime you're cruising under 50 mph should work wonders
Interesting to consider variations between individual cars. Tire pressure? Wheel alignment?I drive speed limit + 5 MPH, and get rated (not ideal) range or very close to it, unless the speed limit is 70 or over for big stretches.
It seems like there's a lot of difference between cars. I've always wondered if it was wheel bearing or something.
Probably not the cars. More likely the driver, terrain, weather.Interesting to consider variations between individual cars. Tire pressure? Wheel alignment?
On average, Model S owners achieve about 70% of Rated Range. Can be seen here as "efficiency". TezLab
I also notice my wh/m number average slightly improve when my tires are wearing out (i.e. lower rolling resistance due to reduced tread)Interesting to consider variations between individual cars. Tire pressure? Wheel alignment?
Compared to older Model S cars, that 253 wh/mile is pretty incredible. Mine is 351 averaged over many years. Earlier in this post, the older Model S cars seemed to average in the low to mid 300's. One time, trying really hard, in ideal conditions, I got 307 wh/mile on a 200 mile circuit. You would drive yourself crazy trying to do that regularly.I have a 3 month old MS LR plus with 2,675 miles.....two road trips of over 475 miles for each one....rst of driving is around town but have been shut down for a while and dont drive a lot the last few weeks....I have alternated between supercharging and home charging.....I have a wall charger Nema 14-50 but it was internal bad causing the heat sensor to lower the current from 40a to 30a....this behavior continued until the car was charged to what I have set......it did it for both cars....changed it out for a new hard wired wall charger and last 3 charges have been at 40a...so problem fixed.....I am getting for the life of the Model S LR Plus an average of 253 wh/m for 2,675 miles.....the road trip were taken in February to Yuma, Az and air conditioning was used......I averaged around the same for that trip.....I am sure because of the Lowe mileage overall, I should balance out soon and see maybe a little higher wh/m but right now I am a happy camper
My 2015 S85D shows 296 Wh/mi over long term (86,000 miles)Compared to older Model S cars, that 253 wh/mile is pretty incredible. Mine is 351 averaged over many years. Earlier in this post, the older Model S cars seemed to average in the low to mid 300's. One time, trying really hard, in ideal conditions, I got 307 wh/mile on a 200 mile circuit. You would drive yourself crazy trying to do that regularly.
Either the new cars are spectacularly (30%) more efficient, or the wh/mile displayed is a poorly estimated value in one or both of our cars.
Weight and weight distribution can't be much different. I thought that the biggest contributor to increased efficiency was the newer front motor.Is the weight lower on newer cars?
