Lifetime Average Wh/mi
ArtInCT
Always Learning
Sep 2, 2014
1,713
433
Southern Connecticut
After 22 months of ownership here are my P90DL's numbers
Current Month December
Distance in Miles = 487
Total energy kWh = 207.6
Avg energy / Mile in Wh/m = 426
Avg Temp 31.6 (from TeslaFi)
Lifetime (22 Months)
Distance in Miles = 26,124
Total energy kWh = 8475
Avg energy / Mile in Wh/m = 324
This month's data reflects very cold weather driving with use of cabin heater, heated seats and steering wheel as well as defrosters and no use of air conditioning. Battery degradation since new is about 3% at 90% charge (241 new vs 235 now). Winter tires have been installed (Micheline MXM4 19" and Tesla 10 spoke wheels). Normal daily charge level of battery is set to 60% due to my daily use case.
Range Mode OFF entire month and on firmware = 2017.50.2 3bd9f6d.
jerry33
Mar 8, 2012
19,516
21,710
Texas
ArtInCT
Always Learning
Sep 2, 2014
1,713
433
After 23 months of ownership here are my P90DL's numbers
Current Month January 2018
Distance in Miles = 101.1
Avg energy / Mile in Wh/m = 459
Avg Temp 31.4 (from TeslaFi)
Lifetime (23 Months)
Distance in Miles = 26,345
Total energy kWh = 8576
Avg energy / Mile in Wh/m = 326
This month's data reflects very cold weather driving with use of cabin heater, heated seats and steering wheel as well as defrosters and no use of air conditioning. Use of the S this month was minimal. Battery degradation since new is about 3% at 90% charge (241 new vs 235 now). Winter tires have been installed (Micheline MXM4 19" and Tesla 10 spoke wheels). Normal daily charge level of battery is set to 60% due to my daily use case.
Reactions: David29
efusco
Moderator - Model S & X forums
Mar 29, 2009
5,421
666
Nixa, Missouri, United States
Had been at 304 Wh/mi for almost a year, but this winter drove me up to 305 Wh/mi despite my lifetime distance. Gonna be tough to get it to 304 again.
*edit, this is the 2012 S85 Model S.
Reactions: David29
apacheguy
S Sig #255
Oct 21, 2012
5,071
1,238
So Cal
S85. 21” wheels. 340 wh/mi since about 10 k miles. Now at 90 k. I’m amazed at how constant that number has been given a couple DU replacements and a new pack.
Reactions: David29
EdA
Model S P-2540
Mar 24, 2011
2,267
234
Cape Cod
Very impressive, it would appear to me that your commute is downhill both ways :)
Don't recall ever having a 20+ mile ride in the 20x Wh/mi range which didn't involve a lond downhill.
jerry33
Mar 8, 2012
19,516
21,710
Texas
But notice the average speed is less than 30mph!
It's urban driving there are some long stoplights and low speed limits for the daily, the lifetime is made up of about 50% commute and 50% long distance (over 1500 km) travel.
jerry33
Mar 8, 2012
19,516
21,710
Texas
That's actually one way. the round trip is between 220 and 240. I don't use the same route both ways.
Also there is not that much downhill, it's kind of up and down. Going home is mostly freeway because that gives a better Wh/mi than the surface streets.
AWDtsla
4,262
3,952
NE
Lifetime trip meter: 401 Wh/mi
Real consumption calculated over last year with Teslafi data (excludes preheating while plugged in): 535Wh/mi
Sandollars
I bleed Cardinal
Feb 19, 2018
335
320
So Cal/So UT
I know this isn’t scientific but it DOES show a trend.
When this thread was started, the first 20 to report had a cumulative average of 374wh. That was 2013.
The LAST 20 to report in 2017 had a cumulative average of 298wh.
Either we are getting better at lying or driving OR the car’efficiency just keeps getting better! I am joking about the lying!
Regardless, I can’t wait for mine to be delivered and I am happy to find this forum of fine people!
Chaserr
Hyperactive Hyperdrive
Sep 5, 2017
2,656
5,569
Logan
@Sandollars - It could be a little of each... Your average whm will be much higher for the first few months of ownership than it will be later on. Unless you have superhuman restraint, it's going to be difficult to avoid using the instant acceleration your new car has, and while that doesn't help efficiency it does help install the permagrin. Welcome aboard!
ArtInCT
Always Learning
Sep 2, 2014
1,713
433
After 24 months of ownership here are my P90DL's numbers
Current Month February 2018
Distance in Miles = 507
Total energy kWh = 190
Avg energy / Mile in Wh/m = 375
Lifetime (24 Months)
Distance in Miles = 26,867
Total energy kWh = 8765.7
This month's data reflects cold weather driving with use of cabin heater, heated seats and steering wheel as well as defrosters and no use of air conditioning. Use of the S this month was less than normal. Battery degradation since new is about 3% at 90% charge (241 new vs 235 now). Winter tires have been installed (Micheline MXM4 19" and Tesla 10 spoke wheels). Normal daily charge level of battery is set to 60% due to my daily use case. BTW the 12V battery was changed this month for the first time.
eschummer
105
85
San Francisco, CA
I have mine set to metric units. 191 Wh/km over nearly 50,000 km just sounds better than the equivalent 305 Wh/mi ;) I still can't resist putting my foot down every so often. OTOH, between my solar panels at home and the SC's for longer trips, I can (almost) say I've been driving for free...
