Oh no, the subwoofer is ridiculously overpriced. You can get a much better sub from Sound Qube for $100 that is basically a drop in replacement... but to take advantage of it, you'll need an amp, otherwise it's weaker than the stock sub.
HDS208 Dual 2
They have sales pretty often, so you can get it for less than listed there if you wait around.
The door speakers, as I said, don't really add much, if anything, to the soundscape inside the car, I would definitely skip those. A sub and amp will be your best bang for the buck. The problem with doing amps in the Tesla is the door speakers are all 1 ohm, so you need a sub that's stable at 1 ohm and that's hard to come by, other than the LH amp.
Otherwise, yeah, you have to replace your speakers along with the sub and go aftermarket traditional amp. You can get much cheaper, better door speakers from the usual car audio suspects than the relatively generic LH ones.
In the end, if you don't want to go the LH way, get a traditional 5 channel amp, a wiring kit (or custom loom) to output to the doors and sub from the Tesla harness. The advantage of the LH amp is that it's plug and play and easy to DIY. The disadvantage is QA (high probability of multiple failed amps) and insanely long RMA time, coupled with spotty communication.
Someone could just make an adapter and then you could use whatever AMP you want... I agree with your assessment, you only need their AMP the Tesla stock speakers are pretty good on the UHFS.
Reus seems to think so as well, which surprised me. He added a Sub, crossovers, amps, tweeters, and center channel enhancement -- but kept the UHFS speakers in the doors. He said they are more than fine.
My idea was to just make a block harness that has a passthrough for all the channels except the 4 door mids and the sub, which would be output to bare wires that you just wire in to whatever you want.
The LH sub does the 4 doors and the sub.
If there's renewed interest in the harness, I can look at getting it created... but the nagging question right now is what happens when the MCU does not see the amp on the line, if it disables the output. If it doesn't, then the adapter will be easy, if it does, then it requires a whole different problem to be solved by tapping the outputs at the MCU, or making the MCU think there is still an amp attached.
I assume you meant "The LH amp does the 4 doors and the sub."
I'm not convinced that is true.
I found this online: https://teslatap.com/articles/audio-systems-for-the-tesla-model-s-and-model-x/
Here's what TeslaTap says:
In the standard system, each of the four 6” door mid-woofers and the 3” center mid-range get a separate 40-watt A/B amplifier (5 total). The tweeters are passive on the standard system and are likely powered from the two front door speaker amplifiers.
Ultra gets an additional 7 channel 360-watt class A/B amplifier that resides below and behind the instrument display. The Ultra configuration moves two of the 40W channels from the primary amplifier’s front doors to the two additional 3” dashboard mid-range speakers. The added amplifier provides 20 watts to each of the tweeters, 80 watts to each of the larger 8” front door speakers, 40 watts to each of the 3” rear hatch speakers, and 80 watts to the rear 8” sub-woofer.
The sub-woofer is mounted in the right rear corner, and is not directly visible. Tesla uses a custom designed 6.6 gallon (25-liter) enclosure for improved low-end response. This enclosure is considerably larger than most other sub-woofer equipped luxury vehicles.
It indicates the the Tesla premium amp - and presumably the LH amp - DO NOT power the rear door speakers. The rear doors are power by the main amp. The Tesla premium amp - and presumably the LH amp - power the front doors and rear hatch.
There is also the attached diagram, which I think came from LH, that supports the Tesla premium amp powers the front doors and rear hatch:
Has the general feeling toward LH that they are no longer a fly-by-night shady company and that they seem to be getting their act together with regards to the warranty repairs? And is the feedback still generally good for the door speaker replacement while preserving the factory amp on the non-Ultra audio system?
TeslaTap says the UHFS amp is 7 channel while the diagram shows 5 channels. Both do show that the UHFS amp is not powering the rear door speakers. There would be one way to confirm this would be to unplug the UHFS/LH amp and check which speakers still play. I'll do that in a few days. LH sent me notice that they've shipped a fourth replacement amp.
What I guess that answers that question.....DO NOT BUY ANYTHING FROM THIS COMPANY
these guys do not care.
I was one of the original people to order the full package.
firstly it was several months late
next the SUB was horrible and all users complained
they said they would fix the issue and ship a new SUB and swap for the bad one
NEVER HAPPENED
its been over a year now.
DO NOT ANYTHING FROM THIS COMPANY
Guys like this should be put out of business.
Larry and Manny do not care and will take your money- period.
Larry i have emailed you many many times- you keep lying about how manny or yourself will take care of the issues.
You never have.
So now - your business MUST come to an end.
Stop ripping off good people.
