Lighted Tesla T Pre-order List
Discussion in 'Tesla Parts for Sale' started by artsci, Nov 26, 2013.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    #1 artsci, Nov 26, 2013
    If you think you want to buy the lighted Tesla T kit when it's available in mid-December please add your name to the pre-order list below. An extensive discussion and more information is available in the current thread about the project. The kit will include the lighted T and arch, assembled and waterproofed along with detailed installation instructions.
    Cost
    The cost of the kit is now estimated at $180 - $190. 50 kits will be available from the first production run. When the list reaches 75 a second production run will be launched. The kit will include the lighted T and arch, assembled and waterproofed along with detailed installation instructions.
    [Admin note: Following post is a wiki which you can edit]
  2. artsci
    artsci Sponsor
    Timonium, Maryland
    #2 artsci, Nov 26, 2013
    Orders can now be placed here:
    Pre-order waiting list:
    1. nkohlimd
    2. npiwovar
    3. rogbmw
    4. suprkar
    5. The Fury
    6. zax123
    7. brianman
    8. xhawk101
    9. ccbldg
    10. jamtek
    11. jason
    12. walla2
    13. bad luck
    14. shumdit
    15. KlausFechner
    16. yobigd20
    17. Jetson
    18. 1051
    19. ArthurHansen
    20. islandbayy
    21. Soarteeth
    22. tomanik
    23. umuhk
    24. efusco
    25. 4super9
    26. dsmith2189
    27. Logan
    28. rekoh
    29. professionalr
    30. KineticFlow
    31. ModelS1079
    32. Chas F
    33. phx182flyer
    34. gwagen27
    35. pwrmeup
    36. scriptacus
    37. Odenator
    38. SamGarber
    39. RLA12194
    40. WeazL
    41. jpasqua
    42. NJ Plugin
    43. SteveW25561
    44. TSLAopt
    45. pudljmpr
    46. Cards2011
    47. bhuwan
    48. drtko147
    49. ggbjr
    50. mknox
    51. inottawa
    52. joefee
    53. NoMoGas
    54. deinspanjer
    55. randyy
    56. SouthJerseyJon
    57. Malnodnarb
    58. Surfrcali
    59. ​Jayfrost
    60. ​Btrflyl8e
    61. AlMc
    62. gnelson
    63. Najeeb
    64. RandyS
    65. mpbruin108
    66. ​dratifk
    67. smartypnz
    68. ​Musterion
    69. ​pgiralt
    70. Denarius
    71. Iconoclast
    72. Ben W
    73. Tezco
    74. dpodoll*
    75. Jhall118
    76. muleferg
    77. mahedy
    78. Warrenbonz
    79. Norway
    80. LastNLSig
    81. cgiGuy
    82. dpodoll
    83. blokhus
    84. paltschuler
    85. Solarguy01
    86. demetri
    87. miamimd
    88. Patrick
    89. ABVA
    90. Id2020 (post 53)
    91. Jau24 (post 54)
    92. Jmarlene (post 55)
    93. Honolulu MS
    94. Vger
    95. mmedina (post 57)
    96. A-E
    97. mjw
    98. SouthJerseyJon
    99. alexhamilton7
    100. tdchinn
    101. cadester
    102. alexhamilton71
    103. Asif
    104. nomoregas
    105. tnguyen1221
    106. pollux
    107. mpbruin108
    108. passion4audio
    109. Ato J. Boldon
    110. MyDreamCar
    111. bluetinc
    112. SteveWest
    113. diaretical
    114. bradhs
    115. jerry33
    116. msolomi
    117. andrewket
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    #3 artsci, Nov 26, 2013
    Recommended remotes:
    Oznium 12V LED Dimmer and Strobe Remote Switch
    Oznium Remote Control On/Off Switch
    The Oznium remotes synch with Homelink very easily making off-on control of the T from the touchscreen quite simple. Oracle remotes, even though they sync with Homelink, are not recommended, as in my experience have an unacceptably high failure rate.
    Installation
    Installation is an easy DYI project or can be done by a auto accessory shop. It requires removal of the nose cone, drilling of two 5/64 holes in the nose cone under the T and arch mounting position, connecting the T to 12v and ground with a buyer-supplied device that will provide remote control.
    Other parts required include remote control, tap-a-fuse, 18 gauge wire, Goop or 3m double faced auto tape.
    Tools require include a power drill, 5/64 drill bit, plastic lever for prying the nose cone loose.
    Photos and video of beta
  4. Klaus
    Klaus Member
    Sorry, my entry takes up 2 slots, apparently due to auto-wrap. I don't need two :rolleyes:
  5. artsci
    artsci Sponsor
    Timonium, Maryland
    Got it.
  6. 4SUPER9
    4SUPER9 Active Member
    Please add me too
  7. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Absolutely!
  8. KineticFlow
    KineticFlow New Member
    Young
    add me as well
  9. ModelS1079
    ModelS1079 Member
    Suburban Boston
    Bravo! Looks great
    List me please. Thanks.
  10. PWRMEUP
    PWRMEUP Member
    Scottsdale
    Looks awesome!
    Please add me.
  11. gwagen27
    gwagen27 Member
    Southern California
    I just added myself to your list. Thanks in advance!
  12. TSLAopt
    TSLAopt Supporting Member
    Northern Cal
    Add me too please!
  13. pudljmpr
    pudljmpr Member
    pudljmpr
    Add me as well
  14. Cards2011
    Cards2011 Member
    Racine, WI
    Please add me!
  15. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    Added my name too!
    Btw, does the Oznium remote you suggest remember its power on/off status when the 12v is restored? In other words, I'd like to hook the circuit up to a 12v source that is switched (accessory feed) and use the Oznium remote to set the brightness level, but then have the whole thing turn on or off according to the car's accessory on ("ignition") status? If I understand correctly the Oznium system remembers its own brightness or strobe settings when you turn it on or off, but the Oznium itself needs to be turned on or off using the remote. Will the Oznium turn on and off using just the 12v accessory on/off status, without me remembering to use the remote every time?
    Alternatively is there a way to just set the LED brightness and have the T simply switch on and off with the 12v accessory circuit?
    Thanks for this cool mod!
  16. bhuwan
    bhuwan Active Member
    Boston, MA
    Me as well - hasn't we emailed you a few weeks ago too?
  17. drtko147
    drtko147 Active Member
    Waialae Nui, Hawaii, United States
    Add my name to the list.
  18. ggbjr
    ggbjr Member
    NC
    Me too!
  19. gwagen27
    gwagen27 Member
    Southern California
    TSLAopt, pudljmpr, Cards2011, bhuwan, drtko147, ggbjr...I added you guys to the list. Artsci, hope that is ok.
  20. blokhus
    blokhus New Member
    Bergen, Hordaland
    Please add me as well.
