Thats a non issue.
You tell that to competent electric engineers, specialized in high power currents.
Thats a non issue.
If you look very close under the skirts and in the pants of "project better place" you find out that is a well thought and well maketet (till Olmert in Israel) scam - to lure the public with a shrewd green argument from one dependency (oil) to the next (one single monopolistic battery producer, marketeer & technology!).
Well, that is called the basis of a de facto standard and if no one else will step up and propose something, it might as well be his organisation...
So it would matter if the proposals are filled by no-bid-contracts and here are open source specs so any manufacture can make aftermarket bits that owners can buy.
ABG has a bunch of pics. It definitely seems to move under it's own power.
As for fastcharging, that recently tested 2Mw could fill up a Lightnings, or whatever, all day long. 3 minutes seems a bit fast though. Most articles state 10.
OK so I had a bit of a think about this cable requirement and came up with the following. Maybe someone can check the maths.
Based on a typical 13A cable having cores of 1mm diameter, I recon you would need three cores of ~27mm diameter for a 3 phase system (I'm assuming UK 415v three phase here). Not including insulation, that means a 77mm diameter overall cable.
Taking the density of copper as 8950kg/m3, that leads to a cable mass of 15.5kg per metre, plus insulation.
Not out-of-the-question heavy, but certainly very unwieldy. Think of an F1 refuelling hose.
No idea how much difference braided cable makes to this, and this assumes 100% efficiency in the charging for the assumed supply current.
Those images are way too big to place inline on this thread. Can you find smaller ones and link to the larger ones? Or just leave a link with no image.
Btw, Notice Darryl and Aaron in the background?
