Likely MCU Failure (MCU1 eMMC)
Discussion in 'Model S' started by Jkaufm32, May 15, 2019.
  1. aerodyne
    aerodyne Member
    Los Angeles
    Or maybe just get it fixed under warranty...that is an option for many folks..
  2. arcus
    arcus Active Member
    Denton, TX
    I second that. They also look into things such as history of servicing and ESA.
  3. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Moderator note: All prior posts in this thread are the result of merging multiple threads started on the same topic.
    When thinking about starting a new thread, please do at least a casual search to see if what you have to say might fit well in an existing discussion.
    Thanks!
    Bruce.
    • Helpful x 2
  4. iRia
    iRia Member
    New Jersey, USA
    I would expect for a 100k+ car that it shouldn't have such a glaring design defect.
  5. aerodyne
    aerodyne Member
    Los Angeles
    Yes, but other 100k cars have issues too, like Stealerships that bend you over for routine maintenance. Said maintenance largely not required for EV's, so if you pay 2-4k for a major item like the screen after 4 years, consider the MB or BMW or Porche costs during that time.
    • Disagree x 2
  6. TJtv
    TJtv Member
    NJ
    Is there any way to have the system create extra write cycles? If so, you could intentionally cause the chip to fail while still in the warranty period.
  7. djvelocity
    djvelocity Member
    NOVA
    Is this really true about maintenance though? It seems lots of DUs have failed, even amongst newer cars, and my thought is that maybe oil changes are wise and needed to help avoid some of these problems that develop over time. Ditto with coolant. Do we know if there’s a possibility of a gasket failing that would allow coolant and oil to mix, which would also require a maintenance to replace such a gasket? There is lots of tech talk here, which is good, but the absence of any mechanical discussion and the though that these machines should be maintenance free is troubling to me. I don’t think any company should get a pass on such a claim, even if the maintenance intervals might be longer due to gentler conditions when comparing ICE engines to EV drive units.
    That stated, it seems thus eMMC issue is largely software/write volume driven and can be essentially mitigated by software changes that avoid the write volume. That’s more a bug/flaw/defect in my mind than routine maintenance that anyone should have to expect to cover. Just my opinion.
  8. iRia
    iRia Member
    New Jersey, USA
    This doesn't matter. Tesla touts no maintenance, and this isn't even maintenance. It's a defect. It's one thing if it's an easily replaceable unit but to do the repair you either need to do BGA soldering or replace the whole unit.
    This would be the equivalent of designing a car with brake pads that always rubbed against the wheels so they wore faster than they are supposed to. There is no reason for it, but you're stuck with it because of a poor design.
    A properly designed system would minimize writes to flash memory and instead use a RAM disk for Linux logs.
    Seriously, don't excuse them. They clearly dropped the ball, can fix it and they should.
  9. iRia
    iRia Member
    New Jersey, USA
    Oil changes in an ICE are necessary because the oil is subject to extreme heat and chemical changes from exposure to the byproducts of combustion. The drive unit fluid is similar to that of an automatic transmission and many manufacturers are simply sealing the whole thing off now and not recommending any transmission fluid changes. I know some people miss the whole wrench turning experience they had with an ICE but it's unnecessary for the most part.
    That seems like it. I do Linux system engineering for a living and most of the logs you see have zero to do with the car's operation and would be just fine in a RAM disk. Any anomalies can be sent to Tesla remotely anyway if they really need to collect the data.
  10. demundus
    demundus Active Member
    Oceanside, CA
    a week tops? i cant really remember... it wasnt forever.
  11. IronPig
    IronPig Member
    Los Angeles, CA
    From those that have had this happen, are there any warning signs before the screen goes dead? I have a 2014 with 46k and it updated to new software ok last night, but I'm just curious to see if there is anything specific to keep an eye on.
  12. tpedwards
    tpedwards Member
    Nashville, TN
    Look for anomalies - more lockups that require MCU restart should have been a clue for me. Car was disconnected AND had PIN to drive enabled - doh! It would not charge, would not drive and was completely disabled. Manually disengaged Supercharger and left for the Tesla approved towing company. Time to replace would have been half a day (granted they gave me priority as an out of town traveler), but it was Easter weekend and there were no engineers in Palo Alto on Saturday to generate proper firmware. They sent me home in a loaner and we exchanged the following Tuesday.
    They keep MCU1s on the shelf for this, but they still have to schedule you in, get you in, replace the unit and generate and install fresh firmware.
    The service center in Indianapolis was quite gracious and I ended up with an LTE upgrade in the process in my 83,000+ P85D.
  13. Shadious
    Shadious Member
    Florida
    Interestingly enough, I spoke with a Tesla mobile ranger who told me they are noW replacing MCU 1 with MCU 2. He said they have an adapter for the plugs and you get the full on new MCU 2 when it is replaced. Is that true- not sure, but I asked the question 5 different ways and he was pretty confident. As an aside, was told that this may not be public knowledge. Anyone out there have ANY confirmatory evidence that this is the case? I am skeptical, so I’d like to see something definitive...
    • Informative x 4
  14. fetzu
    fetzu Member
    Switzerland
    I have had audio stutters, garbled fonts and "broken tiles" on the map (displays noise in a square instead of the actual map). I also had a weird bug last year where my MCU would crash (and reboot) everytime I drove at the same spot, but only during daylight (I figured it was also some corruption on cached data, the support was of no help and the problem eventually went away).
    I have repeatedly contacted support and went to the SC to have them diagnose the issue, and their only response was "a firmware update will fix this" and "reset trip meters and recent locations in the nav".
    Are those issues telltale signs that my MCU is starting to fail? What would the next failure be (blank screen.. random crashes and reboots..)?
    As my warranty is coming to an end due to mileage, I'd like to get them to get me a new eMMC/MCU to spare myself the couple grand when my MCU will inevitably fail a few hundred miles past the warranty..
  15. David29
    David29 Supporting Member
    DEDHAM, MA
    Nothing I was smart enough to notice. The car seemed normal right up until the software install failed.
    And, caveat -- at this moment, i do not know for sure that my car has had this exact failure. SC is looking into it.
  16. cucubits
    cucubits Member
    TX
    I was just thinking about this for those who are close to out of warranty. Since it appears to log way more on screen button presses, it would probably be easy to make a little device with one of those touchscreen pens to just move up and down and continuously click many many times a button :cool:
  17. BIG ACH
    BIG ACH Member
    Orlando, Fl
    That was me yesterday - damn near gave me a heart attack lol
  18. StarLog
    StarLog Supporting Member
    MCO
    Has any one contemplated a class action suit.?
    Not my area of knowledge, but would that get anything going.?
  19. StarLog
    MCO
    Can you call or go back, and ask for part numbers for this and a cost.?
  20. Dysong1
    Dysong1 Member
    East Coast
    Update - strangely, my car was acting normal today and center screen had no glitches. Service center tech called me this afternoon and said that they would push me the newer, just-released software version to see if it fixes the problem. He didn't think it was the eMMC.
    Downloading the update as I'm typing, so keeping fingers crossed.
