Linkker - electric bus from Finland
Discussion in 'Electric Vehicles' started by Panu, Feb 19, 2015.
  1. Panu
    Panu Member
    Uusimaa, Finland
    Helsinki, the capital of Finland is starting to use electric busses from this Finnish company:
    ABOUT - LINKKER
    The idea is to always charge it at the end of the route:
    "Range 30-50 km
    Battery capacity 40 - 48 kWh
    Fast charging with 200kW charging power for 3-7 minutes charging"
  2. vinnie97
    vinnie97 Remove incentives, wall practically builds itself.
    southwest
    Isn't that approaching supercapacitor rates? The SpCs are a "mere" 120...
  3. Saghost
    Saghost Well-Known Member
    Delaware
    I don't know that you need a super capacitor for that - but at 5C that's well up into LiPo territory.
    It is likely also only lower states of charge and accepting some battery heating during the short charge, relying on thermal mass to keep from overheating.
    200 kW for 6 minutes is only 20 kWh...
    Walter
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Maybe lithium titanate. That is used by Proterra in the USA.
    One day maybe, city buses will be electric because it's the best value for money. We can hope.
  5. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    Yes, from their homepage:
    Battery: small size, fast chargeable 40 - 48 kWh Lithium Titanate (LTO) battery
