I believe to make a passable demonstration, they'd need to charge 80% (from 10%-90% SOC) of the 85kWh battery in 10 minutes. That means at least 410kW.
So I don't think it's going to be particularly bothersome if the demo is for a 50% / 150 mile charge within < 10 minutes. For that you "only" need 240kW.
That demo would get panned by the press. The average joe knows that he pulls up to a pump and pulls away in about 5-10 minutes with 300-400 miles of range. 150miles in 10 minutes, while a huge improvement over the current state of the art, will not play well when you pit it against an example everyone is familiar with (a gas fill up). Then again most all the announcements during this "5 part trilogy" have fallen short of their billings, so you might be right.
Super Capacitor Range Extender*
Optional, small charge storage device which is permanently fitted into the frunk - so obviously you lose luggage space but you gain X kWh of energy storage.
Cabling for this is already installed behind the panels in the frunk in existing vehicles.
Firmware upgrade needed in addition to the hardware.
Bypasses the main battery and on-board chargers when supercharging only allowing higher charging rates.
Charged in a few minutes. Provides N miles of range.
Can be charged from normal outlets at appropriate lower rates.
System is either /or. Either you charge/discharge the main battery or you can charge / discharge the range extender, but you can switch between them at any time.
Usula caveats apply. Don't drive around with a full battery in hot weather.
* just an idea. No evidence
If it is a battery swap demo, I am shorting the stock. Better Place wasted $800 million trying to make that work. It is a horrible idea.
I am hoping it is dual (or more) Superchargers plugged into the same car. Some sort of arrangement where they can recharge seperate sections of the battery pack at the same time, cutting the recharge time in half.
Those stations are being designed for 4-10 Superchargers. 800 amp service on one of the permits that I saw. So the raw power is there for multiple Superchargers to be working at the same time.
What kind of battery swapping infrastructure is at Hawthorne? I vote messing with you.
By the way, what time is the demonstration and who's broadcasting it?
Nothing safety related will ever go in the frunk and any energy storage device would be in that category. The car would need connectors routed. I'm pretty sure it'd need a fire wall as there is none now. It'd require new crash tests. Etc.Optional, small charge storage device which is permanently fitted into the frunk - so obviously you lose luggage space but you gain X kWh of energy storage.
