List of Homelink Garage Door Openers That Work
Discussion in 'Model S' started by finallybuying, Jul 26, 2016.
Tags:
  1. finallybuying
    finallybuying Member
    Menlo Park, CA
    Having a garage door redone. Can't seem to find a simple link or something to forward to my contractor to show which garage door openers will work well with Tesla. I understand that Homelink is supposed to work but I keep seeing posts where some work and some don't. Is there a definitive list somewhere?
    Thanks.
  2. superm1
    superm1 Member
    Fremont, CA
  3. miggz410
    miggz410 Member
    Bay Area, California
  4. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    My Liftmaster works super
  5. JPUConn
    JPUConn Active Member
    CT
    2nd Liftmaster - mine is a side mount.
    The trick for me was to hold the remote in the Frunk by the light/release lever to program.
  6. OlderThanDirt
    OlderThanDirt Member
    Two Rivers, WI
    Geni here. Literally only few minutes to set up. Auto open and close working perfectly.
  7. finallybuying
    Menlo Park, CA
    Thanks. Ideally I'd have a list somewhere...? Is there one?
    (Long story but I have a difficult garage door, so want to give full choice.)
    If I tell him it must work with Homelink is that enough? (I keep reading things that imply not.)
    Thanks.
  8. tstafford
    tstafford Supporting Member
    Nashville, TN
    We have a Hormann and it works fine with Homelink (both the Tesla and a Porsche) but I'm not a huge fan of it otherwise.
  9. Fluke
    Fluke Member
    Stilwell, KS
    The Chamberlain mentioned above from Home Depot has worked well for me also. The Chamberlain replaced an Overhead Door opener that was installed in 2014 and did not work well at all with the Model S.
  10. superm1
    superm1 Member
    Fremont, CA
    I'd just go with the chamberlain (hd950 or hd1000) or liftmaster 8550w. they are made by the same company so I think the same product.
    The good thing about the one in the link is that usually you have to buy a separate bluetooth/wifi module and this one has it built in so it ends up being cheaper.
  11. rhumbliner
    rhumbliner Member
    Jackson.Hole Las.Vegas
    I can verify that the Odyssey 1000 by Overhead Door works and like @JPUConn I had to hold the remote inside the frunk.
  12. Kevin_Freeman
    Kevin_Freeman Supporting Member
    IL
    The HomeLink technology standard was updated about 4 years ago - so you should be OK using any recent opener from major brands. For Chamberlain / LiftMaster look for Security+ 2.0. And pester Tesla to integrate with MyQ so you don't need HomeLink or a clicker.
  13. finallybuying
    Menlo Park, CA
    Thanks.
  14. rickrickrick
    rickrickrick Member
    West Chester, PA
    My DirectDrive openers do NOT work out of the box with the HomeLink in my S. The frequency is off by 5 MHz but DirectDtive sells an adapter. My recommendation is to do a quick search of the boards after you have a short list of openers you are considering.
  15. Austral
    Austral Member
    Even moderators don’t follow forum rules....
    The Homelink on my S started to have problems about two weeks ago. Started to think the S was the source of the problem, perhaps a bad transmitter. Also considered an alternate hypothesis that the garage door receiver was the problem. Did some research and what did I find?
    I discovered that neither the S or the garage door receiver were the problem. LEDs! About two weeks ago I replaced the bulb inside the Liftmaster opener with an LED bulb. Apparently there is a frequency management issue--overlap between the freq' of the bulb and the garage door signal. Here are some links that may help explain:
    https://www.liftmaster.com/catalogresourcesv3/en-us/shared/files/tucmanuals/led%20bulb%20compatibility_011714.pdf
  16. MorrisonHiker
    MorrisonHiker S 90D 2018.48.12.1
    Colorado
    We have three Liftmaster 8500 openers and it was surprisingly easy to link them to the car. Two of them worked first try but the third one took a couple tries. We have no problems with the LED bulbs we use and have the cars set to open the garage about 80 feet from the garage (long driveway).
  17. brkaus
    brkaus Active Member
    Austin, TX
    Looks like an old thread revived :)
    Love the Liftmaster 8500 openers. Significantly quieter than my old openers. And allowed me to change my doors to high lift. For those that haven't seen them, they mount on the wall and twist the jackshaft to raise/lower the doors.
  18. Sawyer8888
    Sawyer8888 Member
    South Florida
    We also have the Liftmaster 8500. Programming Homelink was easy, however the ability of the Tesla to open the closed garage door has proven difficult. The vehicle needs to be parked just right, usually very close to the door or close to the right side of the driveway. It seems the signal is not strong enough to reach the receiver of the Liftmaster unit through the closed door. Closing the door is not an issue. As far as I know, there are no settings that I can adjust to improve the opening signal.
  19. tomp
    tomp Member
    Durham, NC
    I have the same opener and found it very important to program the car's homelink while parked facing the garage and just outside of it. Not sure if that is your issue, but it made a big difference for me. I always park back-in and when I tried programming it with the car facing outwards, the signal was very poor in being able to open the door.
  20. brkaus
    Austin, TX
    #20 brkaus, Mar 31, 2017
    I had to point the car carefully to program it. Otherwise, it's better than my other door that has a chain drive as far a reception.
    Both doors, it really helps for the car to be pointed towards the door.
