Location Based Suspension Not Returnng to Standard Height
Discussion in 'Model S: Driving Dynamics' started by PatL, Oct 12, 2014.
  1. PatL
    PatL Member
    The location based suspension is remembering the GPS location and raises the car as it is supposed to, but when I leave the programmed area, it is leaving it in "High" mode rather than "Standard" height. If I programmed "Very High" it returns to "High", not "Standard". Anyone else seeing this issue or I wonder if am I doing something wrong.
  2. Bighorn
    Bighorn Top Supercharger
    Big Horn, Wyoming
    I lowers in response to hitting certain speed thresholds, namely 22 and 34 MPH.
  3. Cottonwood
    Colorado
    Exactly, it is location based raising, with speed based lowering.
  4. PatL
    PatL Member
    Thanks. I presume the thresholds are not settable by the user.
  5. Bighorn
    Big Horn, Wyoming
    No, they are not. They used to be 9 and 19 which was much less helpful for things like snow drifts and gravel roads. Obviously, you can manually lower the car if you want it lower than the automatic resets.
  6. jerry33
    Texas
    The only speed threshold that can be set by the user is the lowering to low.
