Location of charger in garage - left, front, right
Discussion in 'Model S: Battery & Charging' started by Mickfair, Jan 31, 2013.
  1. Mickfair
    Mickfair Member
    Los Angeles
    What is the preferred location for the wall charger or 14-50 plug?
    i am assuming the left wall so that it is close when I park nose in.
  2. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Where ever is close to the drivers rear part of the car. I back in but the plug is on the passenger side (put the short car in front of the door to the house). It isn't bad at all. I would try to put your cord in an out of the way place if possible but still easy to get to to charge.
  3. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    I think you answered your own question. It depends on where you park and if you back in or pull in.
    There tons of posts about the 'where', but it boils down to 1) which side you park on, 2) if you pull in or back in, and 3) distance from panel (can impact cost). Some people hang it above, others coil it on the wall. I installed my outlet on the post between bays. The cable is long enough to reach either side of my car, whether I pull in or back in.
    Your call.
  4. Longhorn92
    Longhorn92 MS VIN #10103 (40 kWh)
    Chicago
    One additional thought: you can also daisy chain another outlet to your first, such that you have options about where to charge (can only use one outlet at a time though). I asked about this when I got my quote, and it only added about $250 to the price (40' of wiring and conduit, plus additional outlet - surface mounted, so not behind wall).
  5. raptorweb
    raptorweb Member
    San Mateo, CA
    This is pretty close to what I did with my setup, I ran pipe along the ceiling of my garage and put a box about 1/2 way. That way I can put an outlet in that box if needed if I change my mind on how my garage is laid out.
  6. seidste1
    seidste1 Member
    West Bloomfield, MI
    Any good ideas for a shelf or hook to hold the charger cord and plug when not in use?
  7. ElSupreme
    Atlanta, GA
