Locked NEMA 14-50 Outdoors?
pbleic
230
Boston
I am going to be putting an outdoor NEMA 14-50 in a location that is open and unsupervised. Does anyone have experience with locking up access of this type? Can someone post photos and specs of how to do this?
mitch672
1,861
13
Stoughton, MA
The RV Park box I have is lockable, but it's rather large, since it has circuit breakers in it, and a 14-50, TT-30 and a 120V 20A GFCI outlet in it. There are holes on the lower left and right of the cover/body to insert a rod or locks.
buzzbar
7
0
Seattle area
Here's a link for a similar model, much smaller, and it is lockable:
Eaton, 50 Amp 1-Space 1-Circuit Temporary RV Power Outlet Box, CHU1S at The Home Depot - Tablet
By the way, I'm an electrical contractor with nearly 30 years experience in Washington state. Feel free to ask me any electrical questions.
Good luck!
Andy
Princeton96
60
0
Lafayette, CA
Are you looking to secure it when you're not using it or also when you're using it? I used to live in a townhouse complex with carports. I had a weatherproof box installed with a Nema 14-50 plug. When you're not using it, the box closes and you can attach a small padlock to keep it closed. When you're using it, it gets a bit trickier because the cover doesn't close all the way.
Here's a link to my solution. It's at the bottom of page 1. It worked pretty well. I usually just kept the UMC plugged in all the time and locked to the box.
Will the UMC fit when the cover is closed?
Lloyd
6,252
2,039
San Luis Obispo, CA
Here is a much smaller installation, with a locking slot on the lower right I did at my house.
Sorry they oriented sideways.
Max*
Charging
Apr 8, 2015
6,670
3,719
NoVa
Many outdoor NEMA boxes have locking options.
(I don't have one where the cover is closed, but you see the metal loop protruding, that enters the slit in the cover, and you can place a lock over it)
brucet999
2,671
1,482
Huntington Beach, CA
Grease Monkey
New Member
Apr 10, 2016
3
Miami, FL
You might be required to put an additional means of disconnect, like this within line of sight, since you are defeating the regular means of disconnect (the plug). The locks are supposed to remain open when in use if no other means of disconnect are within line of sight. The locks on boxes are mostly meant to protect people servicing the circuits. This prevents someone from being electrocuted because someone else energized the circuit. More info here.​
brucet999
2,671
1,482
No way a Tesla 14-50 adapter fits under that lid when it is locked.
14-50 is not much different from a dryer plug, so unlikely to need a separate shutoff other than circuit breaker. I wouldn't/didn't even pull a permit for such a thing.
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
Disconnect is only required for > 60A (625.42).
FlasherZ
Jun 21, 2012
7,024
1,013
Most jurisdictions require a permit for anything short of a direct replacement of an existing device. Any new circuit or circuit extension generally requires a permit pull in those jurisdictions where separate electrical permits are required.
Rocketship
New Member
Jun 24, 2018
3
2
Seattle, WA
Just joined this forum but have been lurking/researching for an EV solution for my office but didn't know what would work as it's exposed and outdoors. Obviously, was worried about theft / security but was able to come up with a solution based on a lot of what I saw here.
Just wanted to give back to future users to see what can be created.
I came up with the following solution which has been working great. Box is 24in x 24in. Locks easily.
Photos attached:
Reactions: KJD and Acps110
ucmndd
6,213
11,599
That’s a pretty interesting setup. I’ve come across dozens of HPWCs mounted in public locations at this point and never thought of putting one in a giant metal box.
