Log File Reader
Picasso
kllkkjlk
May 8, 2009
218
113
hmm
Have you been able to download any? From what I understand just put in a USB stick with a DIR on it and it will put the logs on it. A few remote tesla roadster users have been sent info on how to pull the logs. If you could post or email one of the logs I will do my best to try and decode it.
My wish is for Tesla to be open about all the controls in the car, This also includes allowing us to write our own firmware. Sure it would void the warrenty but Im ok with that.
Also is a service menu you can access via the display, tap the screen 10 times to enter, need a code. Unsure if its tied to vin...thats the way Id do it. But I think the code is based on what firmware the car has.
You can also talk to the differnt control systems in the car. It IP over can.
Are you looking for errors with the A/C? You should get a temp probe stick it in the vent turn on on AC Full and check the temp. Report the temps you get on full at 2/5/10min mark and report to Tesla. From what I understand the AC is dumb and just turns on/off I don't think it will put any log fwd.
SuperB
20
0
coral springs fl
Yes, I created a log to send to Tesla.
They put a .tar file on the USB device in a folder VehicleLogs, which must already exist. Pretty simple process.
.tar files are just a type of file compression, I decompressed it and there are several files, most are not simple text files, so I can't read them. The text files don't have any meaningful info in them.
The logs were created to diagnose my PEM running hot, not the AC.
mowcow
New Member
Jan 7, 2010
2
0
Code:
Linux version 2.6.11.8-2.1.0
LPC2294
release : vehicle-firmware-4.1.21.23 : 4.1.21 : 4.1.21/ : 23 :
scott451
KWH-PWR#1349Sprt,S Sig#96
Apr 2, 2009
258
2
Palo Alto
Log parsing
Code:
LPC2294
Kind of a boring log file... Lots of stuff in there, but only 20.1 miles on the odometer. Max speed was:
2009/sep/14 00:19:41 am, 29KW 79.5mph.
A couple of recent errors:
2009/Oct/12 23:54:37 Check left front turn signal bulb
2009/Oct/12 23:54:38 Check left back turn signal bulb
2009/Oct/13 00:53:57 Airbag must be serviced. Contact Tesla Service Center.
This log must have been pulled very early, as I can see back to the birth of the car...
-Scott
PS my parser is based on the 2008 logs. The 2010 logs are different in a number of ways, especially wrt charging, they removed one type and added another. It will take a while to decypher the logs for the 2010 charge info...
  • logparse_v15.zip
scott451
Apr 2, 2009
258
2
Palo Alto
Can you share your parser with us?
I'm working on that... It will probably be web based, so you upload a logfile and it sends you the spreadsheet.
My parser works pretty well with the Model yr 2008 log dumps, but the 2010 are different. So I'm working on getting those issues resolved. Anyone willing to send 2010 logs, send me a PM.
-Scott
PS for your records take a log dump every three months, and right before going in for service...
[edit 11-18-2010: my log parser is now available. See attached file]
  • logparse_v15.zip
Alpine Driver
92
0
Austria
Scott,
very interesting thing.
sent you PM. I would like to send a 2010 european logfile, so that this part is also covered.
Hope it does not matter, since the last firmware upgrade (tesla technicians came by), the car is in storage mode and did not move a mile.
best
Martin
doug
Administrator / Head Moderator
Nov 28, 2006
16,873
978
SF Bay Area
-Scott
Interesting. Are you able to get battery temperature data from the logs? It seems to me that Tesla treats that data as proprietary or at least something that gives them a competitive advantage.
Last fall JB gave a presentation at a CARB symposium and quickly showed a couple slides with battery temp data. However, when that presentation became available online, those particular slides were removed.
scott451
Apr 2, 2009
258
2
Palo Alto
Yes and no. It apears that there at four temperature sensors per sheet (11 sheets total). So 44 temp sensors cover 99 bricks. the logs contain only min/max temp of 44 sensors. As far as I can tell, all of the sensors are not logged, only the min/max and possibly the average temp.
Can you be more specific about the slides that were removed?
Thanks,
-Scott
pentest317
New Member
Jun 30, 2017
2
VietNam
-Scott
Please send me your code in log_parse.exe file. I want to edit something in this. Thanks :)
  • Disagree
Reactions: Rotarypower
Roadster
JdeMO Powered
Dec 10, 2016
1,505
1,201
SoCal
1496877
wiztecy
2,905
563
I agree with the pic above. Two things to point out, first explain why you want the code. You said you want to 'edit something". What is this 'something'? Roadster owners have been using this app for quite some time without any issue. Secondly, looking at your post you only have 2 posts, so that's a bit concerning since we really don't know who you are or what you're doing with the code, or even if you have a Roadster. I looked up the other post of yours, and its just plain old nonsense! This is pretty much about what you said, "aaaaaaaaaa". So with that, nobody is going to take you seriously. And from my impression you look like a spammer who just wants to stick malware inside a very good app the community uses. If it was me I'd be like, let me thing about this.... Um, no. Lastly, you do see how old the inactivity of what this thread was.... right? Its over 7 years, so chances that the original code holder is still on this site, which it can be possible, is very slim. And that's the case. He's no longer here. Its like going to an abandoned house since you ran out of milk and asking if they have any. I suggest in the future being part of the community and adding to it before making some odd request.
