Long Range, Rear Wheel Drive Owners - Step in Please
Hello ladies and gents. I'm trying to graph some data for the OG long range, rear wheel drive cars and I'm wondering if you might take a brief moment to help me by sharing some data from your car. Here's what I need:
Your range at 80% charge.
Your range at 90% charge.
Your range at 100% charge.
And also did you ever get the bump from 310 miles to 325.
So in my case here's how it would look:
80%: 260 miles
90%: 293 miles
100%: 325 miles
Rated Range increase to 325 miles: Yes.
I'm going to graph this because I'd like to see where the outliers are on the high side and the low side. Keep in mind I'm only looking for this info if you have a long range, rear wheel drive car. Standard range cars and AWD cars wouldn't apply here.
Your range at 80% charge. 239 miles
Your range at 90% charge. 268 miles
Your range at 100% charge. 300 miles
And also did you ever get the bump from 310 miles to 325. Yes
June 2018 build.
Last time I charged to 100%, it was summer and I was on V9. It was 325 miles. I just charged to 100% last Friday and it’s now at 300 miles. It’s been cold for the past week. Not sure if it’s the weather. Never really worry about it though. I never expect to squeeze out 325 miles, or even 310 miles in a full charge anyway because I drive like a normal driver in all kind of weather.
Last 6 of VIN: 009xxx
Build: March 2018
Miles: 21,200
Firmware: 2019.32.12.2
(Charged to 100% and discharged to <20% within the last 2 weeks.)
80% charge: 246
90% charge: 276
100% charge: Don't have fresh data after the 100% --> <20% cycle
100% when new: 313
Did I get the bump to 325? Yes, but lost it a few months later after a firmware update and a few charges. When it had the bump, 80% charge extrapolated to full was 323 miles.
You guys are making me jealous =(. May 2018 built RWD.
Your range at 80% charge. - 226
Your range at 90% charge. - 254
Your range at 100% charge. - haven't done in a while
And also did you ever get the bump from 310 miles to 325. - Yes
Holy smokes, you are only getting 254 at 90% for an LR RWD? That is probably the worst one I have seen. Have you considered reading the CANbus data at all? It would be interesting to see if you have had your voltage capped. More info here: Sudden Loss Of Range With 2019.16.x Software
