JRP3
Hyperactive Member
Yes, the benefit of Dahn's work is the ability to project the long term effects of additives through improvements in coulombic efficiency without long term testing. Most of his work has been with NMC chemistry but the methods should translate to NCA chemistry. If the right additives can be found to reduce or eliminate undesirable side reactions that would dramatically improve cell performance. Beyond the lifecycle improvements his work on higher voltage NMC might lead to energy density improvements equaling or beating NCA. NMC is traditionally a higher C rate chemistry and slightly safer, so if the higher voltage NMC retains those properties it would trigger across the board improvements in all cell metrics. Exciting times in the battery world.
