DeepBlue3
Do you know what the actual usage is between charge cycles? Whether in Ah or Watt/hours. Would like to know how much power is consumed from 14.15v to 12.6 or when the charge cycle restarts.
All I know is the owners manual in specifications shows 33Ah. The factory AtlasBX for a model 3 is 45Ah.Do you know what the actual usage is between charge cycles? Whether in Ah or Watt/hours. Would like to know how much power is consumed from 14.15v to 12.6 or when the charge cycle restarts.
I installed a battery monitor with a shunt that measures the energy in and out of my OEM battery in September 2021. I have only ever seen it cycle less than 3 Ah from full capacity, which is a very shallow discharge. By the way, my OEM 12v battery is 4.5 years old and has 87k miles.Do you know what the actual usage is between charge cycles? Whether in Ah or Watt/hours. Would like to know how much power is consumed from 14.15v to 12.6 or when the charge cycle restarts.
I was just about to ask you if got anything yet. I’m tempted to install my V3 and see if I have the same results as you on 2022.24.8.Still no VCFront alerts… and now on 2022.24.8
Anyone gotten alerts on this software?
If you do keep us up to date. I have a V4 on the shelf.I was just about to ask you if got anything yet. I’m tempted to install my V3 and see if I have the same results as you on 2022.24.8.
It is possible that my car charges my specific battery more often due to its age or something it measures on it. In my case, it makes no difference if I check the battery meter multiple times a day or let the car sit for 3 days -- it never reads less than about 3 Ah less than a full charge. If I leave Sentry Mode on then it stays at a full charge the whole time.It may be your car is more active than other owner's cars. If a car sits at the airport for a month and the HV batt is off, just driving that card reader and bluetooth could draw more than 3 Ah. The HV batt recharges when the 12v batt gets too low, but a 45 Ah battery shouldn't read as low after only 3 Ah.
What battery monitor did you get?
Will do. Should I top mine off on a trickle charger first? It’s been in the shelf for a couple months. Also can you use a regular 12v battery trickle charger on them?If you do keep us up to date. I have a V4 on the shelf.
Previous versions Sean had said a regular charger BUT I purchase a trickle charger for Lithium batteries on Amazon. I would contact Ohmmu again to see what charger. In theory the BMS should protect the battery but they should know for sure. I also received a letter from Ohmmu that they were considering restarting production of the battery for M3/Y. I would be happy in install the V4 when I see enough usage that the failure messages has been resolved.Will do. Should I top mine off on a trickle charger first? It’s been in the shelf for a couple months. Also can you use a regular 12v battery trickle charger on them?
Yeah, I actually found a Li 12v Battery charger on Amazon. It'll be here Friday. I also have a V4+ on order with Sean but he told me that it's going to be held in their fulfillment area until those are ready to ship in a few weeks. If anything the V4+ has a BT-controlled BMS that he mentioned would allow us to reset the Battery via an App, quick and easy should Tesla trigger one of those hard amber alerts. Hopefully, the latest software from Tesla will prove to resolve the failure messages though.Previous versions Sean had said a regular charger BUT I purchase a trickle charger for Lithium batteries on Amazon. I would contact Ohmmu again to see what charger. In theory the BMS should protect the battery but they should know for sure. I also received a letter from Ohmmu that they were considering restarting production of the battery for M3/Y. I would be happy in install the V4 when I see enough usage that the failure messages has been resolved.
If this is true, how do they ever work in a Tesla, which charges them as if they are Lead Acids?Ohmmu's and other LiFePo4s do indeed prefer a different trickle charger profile from legacy batteries. There are dedicated and dual-mode trickle and fast chargers for them.
Easy. That is exactly where the LiFePO4 BMS comes in, and gets (or at least pre-2022.24.x/.28.x, got) into all kinds of fun arguments with the VCFront BMS logic.If this is true, how do they ever work in a Tesla, which charges them as if they are Lead Acids?
So many people believe a BMS is magic.That is exactly where the LiFePO4 BMS comes in, and gets (or at least pre-2022.24.x/.28.x, got) into all kinds of fun arguments with the VCFront BMS logic.
ANY 12 volt battery 51R with a minimum 33Ah rating (per the manual). Most 51R's exceed that. The factory AtlasBX is 45Ah. Advance Auto has a DiehardEV battery (it's an AGM battery) and is sized the same as the AtlasBX. I had a 51R AGM and the clamp was all the way down. Snug but not tight enough to prevent a small movement. The Diehard fits right. No issues being AGM. 41Ah. Is supposed to last 30% longer than standard AGM. Not suitable for ICE cars nut designed for EV's. Some may grunt it's not lead acid and wont last in Tesla but it has a 3year warranty and they are marketing it for Tesla.I need a 12 volt battery for M3P any ideas. Every place is out of stock
Even Tesla themselves? They are reasonably priced. And given your join date, it should be under warranty as well unless you are trying to do a "proactive" replacement.I need a 12 volt battery for M3P any ideas. Every place is out of stock
