Lookin at Tesla roadsters
Discussion in 'Roadster' started by Emvdl, Jun 28, 2017.
Tags:
  1. Emvdl
    Emvdl Member
    Bay Area
    Looking to maybe buy a tesla roadster...
    I was wondering how is life after warranty? Any good Support?
    What to look for when buying?
    How much is maintainance like?
    Thanks..
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Good luck and the number(s) are HIGHLY variable. I have had my Roadster for 7.5 years and have had no issues keeping it running. Early while under warranty the accelerator pedal was throwing errors causing the car to shut down. The Rangers did a great job and solved the issue by replacing the rear wiring harness under warranty. Then out of warranty the high voltage controller went out and was a $1100 repair. So not crazy but it did have to go to the service center. One other issue was the TPMS sensors needed repaired. We should be able to do that ourselves. And I have learned we can do that on the 1.5 Roadsters. I have started to do all my other maintenance. Fortunately there is a great group here and I have great hope we will keep these cars on the road.
    In buying one it depends on what you are looking for. If you do not have plans to get the 3.0 battery then you want to check the ideal miles on a standard charge. More is better, 185 miles is basically a new battery. Mine after 9.5 years and 44,500 miles charges to 166 miles. I would look at Tom's owners battery study for all the details. Battery Survey « Plug In America
  3. snd92
    snd92 Member
    Norway
    I newly bought a Roadster Sport 2.0 2010 in Norway. 35 000 km, CAC between 152-154 Ah (160 is perfect/new), standard charges between 293-298 km. Considering these values I believe you should look for Roadsters from cold climates, which are basically new after 7 years.
  4. Emvdl
    Emvdl Member
    Bay Area
    Cool tha
    thats. A very good study! Thanks!
