The headlights are completely awesome. They’re super bright. They are leagues better than my 16 Model S (I believe they may have changed suppliers since then though on the S). The fog lamps add quite a bit of dispersed light as well. There is a nifty feature to adjust the beam up and down through the scroll wheel. They’re the best headlights of any car I have owned. Prior to the 3 the Honda S2000 (HID beams) was the best. The S2000 has famously great headlights.
This is interesting to me. My current car has phenomenal headlights and I'm curious how the 3 will stack up. I took a facelifted S home for 3 days on an extended test drive and was gobsmacked at how crappy the headlights were. Indistinct beam pattern and unremarkable brightness. So if I won't be downgrading on headlights, that'll be awesome.
I like to know what “current” car has phenomenal head lights haha.
High beams, residential street. A few street lamps in the area.
Low beams, residential street. A few street lamps in the area.
View attachment 270504 Low beams, freeway off ramp with a lot of other light sources.
No auto high beams......yet.
That sounds too good to be true. What likelyhood are those premium headlamps that will be replaced with cheaper ones in 6 months?The headlights are completely awesome. They’re super bright. They are leagues better than my 16 Model S (I believe they may have changed suppliers since then though on the S). The fog lamps add quite a bit of dispersed light as well. There is a nifty feature to adjust the beam up and down through the scroll wheel. They’re the best headlights of any car I have owned. Prior to the 3 the Honda S2000 (HID beams) was the best. The S2000 has famously great headlights.
Absolutely nothing I've driven in the last year, out of dozens of different model cars. Highs and lows suck now. I'm having trouble driving in mountains these days, because they don't even show around corners: just tunnel vision, and you have no idea what's on the road or where it goes except by memory and driving into the dark by guess.I like to know what “current” car has phenomenal head lights haha.
Something changed. @run-the-joules's current car's headlamps came from an era when good headlamps were still made. I've had many cars with good headlamps and a few with bad headlamps, and I think the headlamps have been getting worse not only because my eyesight is worse but because the headlamps themselves are worse..
Agree. Just went out and snapped a few pics for comparison. Had to drive around a little to find somewhere without streetlights… sorry to the folks whose homes I just lit up!
Low beams:
High beams:
…and now, the Model 3:
Nope. No intention of touching that without a good reason TBH.Have you adjusted the headlights up or down on your Model 3?
Low beams:
High beams:
Those pics were from my Cadillac that the 3 replaced, to give a reference for what I consider good lights.Are you using a HUD? if so which type?
Auto high beams are coming:Is it true that there is no auto-high beams?
Not enabled (Will be enabled soon via over the air updates)
• WIFI
• CALENDAR
• AUTOMATIC EMERGENCY BRAKING
• AUTOMATIC HIGH BEAM HEADLIGHTS
• AUTOMATIC WINDSHIELD WIPERS
• SUMMON
• ON-SCREEN OWNERS MANUAL
• SOFTWARE UPDATE RELEASE NOTES
• REAR HEATED SEAT CONTROLS
• CHAdeMO COMPATIBILITY
