I found this video that shows how an electrical fire can start from a lose connection. Any of you charging using the stock charger (EVSE) on 120v should realize that most 120v outlets are daisy chained together. The outlet in your garage may be 4th or 8th in line from the breakerbox and you could have many connections along the way. Also, many contractors don't install the wires to the outlets by the screws, they simply stick the wire into a clip on the back which can become lose or corroded over time.
Be safe out there folks! Make sure that all connections in any daisy chained outlets are on the screws and are tight!
