loosing serious range with AC on at 75mph
KJD
1,273
903
SLC, UT
What is the outside air temp during that run ?
What is the wind speed and direction ? (Headwind maybe?)
How much uphill on that route ?
Try doing the same route at 65 mph and see what the result is.
roblab
3,341
2,397
Angwin (Napa Valley) CA
And it's not the miles going uphill, but the elevation change. You calculate ten miles drain for every thousand foot gain (hey, it rhymes!). I gain a thousand feet in two miles going up to my house every day. Your quoted wind speed of "mild" means?? 10 mph of wind is the same as 10 more mph drag. And the range already drops 25% when driving 75 over 65. So, yeah, I believe your range is down to 150.
I would recommend watching Trips and slowing down. Unless you're not worried and are going less than 150 miles.
loganintx
608
465
Austin, TX
Just use the energy app, set it to the smallest increment of 5miles and check your average before you get to the hill, after you get tot he top of the hill and then beyond. The car has a LOT of ways to show you average energy use:
1. Since the last time you charged
2. Since the last time you started driving
3. Last 5 miles, 15 miles, 30 miles
4. Trip odometer A and B
S'toon
Knows where his towel is
Apr 23, 2015
3,699
3,639
AB
<snip>
Full article at:
10 Words You Need to Stop Misspelling - The Oatmeal
