I'm pretty sure it's a failsafe system and other sensors will kick in before any damage is caused. There is no way the BMS will allow the battery to get hot enough to cause damage. If you are really worried, put it into track mode as at least that will give you an indication of temperatures on the graphic, although there is some evidence to suggest that it's indicating motor/drive unit temperatures than just pure cell temperatures.Yeah, many thanks for your replies. From Teslafi I think it's clear that the battery thinks it is cold (no regen, constant battery heating), so I'm guessing a thermistor failure(s).
I'm booked in for a service now anyway, so hopefully it will get resolved. I'm just a bit concerned that any further driving could overheat the battery enough to reduce its life. Unless it's a heat pump fault and it is genuinely sucking the battery temperature down and dumping the excess heat to the outside.
I seem to remember the UP car which went up Pikes Peak had a sensor failure during it's race day run which initially looked like a cooling failure but turned out to be a sensor failure. The battery graphic suddenly turned red and power was limited to protect the battery even though there was actually nothing wrong with the cooling system.
