Lost keyfob, any way to locate it using RF signals?
Discussion in 'Model S: User Interface' started by rdrcrmatt, Oct 20, 2014.
  1. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    I know both of my keys are in the house somewhere.. unfortunately I can only find one. I'm hoping the dog didn't eat the other.
    Does anyone have any knowledge of the interaction between the car and they key fob that activates the walk up unlock? I figured it was the car sending out a "ping" for the key fob to sent an unlock signal back and when the car heard the key fob reply to that "ping" it would unlock and present the door handles.
    I'm guessing the key fobs aren't programmed themselves, that the car is configured to only unlock for specific keys. therefor, I figure there is a way to get a key to send out the reply "i'm here" signal and use a very directional antenna to try to locate that signal.
    Hey, its a fun project, and worth trying for the $500 cost to replace a key.
  2. FreeOfPge
    FreeOfPge Member
    Ah, I had the same problem, ended up finding the fob inside the cup holder of the car, hidden under the armrest. I would like to know if you find a way to locate the fob should this happen again.
    If nothing else works, just carry the car around the house until door handles auto present...
  3. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    I guess you could extend the FOB antenna temporarily and wander with it... that'd be interesting...
  4. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    that would be doable, and not all that hard.
    On the other hand, part of the reason for the method I asked about is to get more info about the process. I'm frustrated with how we get no info about how the car works from tesla (no service manuals most importantly).
    Even if I purchase the extended warranty, I'm only going to have 2 more years at most of being under warranty coverage (at 44.3k now in 14 months of ownership). I need info on how to properly service the vehicle. According to the logs, I have a charger that might be offline (only getting 40a charge rates right now), How can I diagnose which charger is kaput, program it and install? That info needs to become available.
  5. Chris TX
    Chris TX Active Member
    Dallas, TX
    LOL! I proposed that exact solution last year for someone that lost their fob. Someone would stand near the car, waiting to see the handles present when the antenna was waved near the lost fob. I bet a temporary Cat5e solution would work.
  6. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    the best solution would be a coax to a .905 meter antenna, (or 1/4 or 1/2 of that length) to wave around. Either way, if playing with my SDR doesn't yield something useful for doing this I will be running around with a lot of coax to find the damn key.
  7. AudubonB
    AudubonB One can NOT induce accuracy with precision!
    That seems a bit more practical than my thought of pushing the car through the house until the door handles responded....
  8. pete8314
    pete8314 Vendor
    DFW, ex UK
    Oh please. Just pop the door off, extend all the cables feeding the door, find the RF receiver under the dash, tape it to the door, and walk around with the door until the handle pops out. Sometimes it's the simplest solution that works :)
  9. FLDarren
    FLDarren Member
    Seminole, Fl.
    Did you take your dog outside to the car to see if he really did eat the fob?
  10. SteveS0353
    SteveS0353 Member
    San Diego, CA
    ROFL. Sarcasm at it's finest!
  11. mgboyes
    mgboyes Member
    United Kingdom
    Recent quotes suggest the fob has gotten a lot cheaper - something like $140 or so. Check with TM before you go overboard building your fob detector.
