Lots of wind noise
Discussion in 'Model S: Interior & Exterior' started by sam46217, Oct 8, 2013.
  1. sam46217
    sam46217 Member
    IN
    I get a lot of wind noise, even water gets in from the windows on my brand new MS, I just took delivery of this great car two weeks ago, the noise is getting worse by every mile. Had anyone had the same problem? I have called Tesla and they are sending someone to look at it.
  2. texex91
    texex91 Banned
    hell
    No noise, no water. Perfect car (minus nav issue which popped its head up).
    Just take it in they will take care of it.
    Enjoy the new car.
  3. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    Do you have the Pano Roof? Some of the Pano's had issues with wind noise. I second the take it in, they will fix it. Tesla's got the best service in the world!
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    The wind noise was worse in the winter (not sure why) but I did just get a trickle of water through the side window at the car wash today. Originally I thought it was coming through the little triangle glass, but today noticed the water was coming in about an inch up the main side glass. It's on my service list when the car goes in next week.
  5. lczand
    lczand Member
    Southern Florida
    Had the problem with my pano roof. Tesla now has fix for it that has to be done at service center. So far, it works with no wind noise above 80 mph which is the speed that mine would start at.
  6. WarrenT
    WarrenT Member
    Orange County, CA
    There are many sources for wind noise issues on this car, so it's really dependent on your service center being able to diagnose it correctly. I had a significant wind noise issue from the front driver side door area that took 3 trips to the service center to finally fix. Initially they replaced all the panoramic roof seals to no avail. Then they were planning on replacing the front little triangle area seal but then decided that wouldn't help. They finally figured out it was something related to the door handle area not being sealed correctly & that fixed it.
  7. N4HHE
    N4HHE Member
    Madison, AL
    I believe I have wind noise from the pillar behind the driver, but not the passenger side. I'll wait for something more urgent before calling for a Ranger.
  8. mknox
    Toronto, ON
    Interesting. I had both the door handles replaced and wind noise at the A-pillar seen to at my last service visit. I now have wind noise that sounds like it's coming from the B-pillar area, but mostly when there is wind from the side of the car. I wonder if it is actually a door handle seal?
  9. SBerg
    SBerg Member
    Solvang, CA
    I have a little whistle at speed, but then I drove our BMW and realized the same noises are there, I just didn't notice them. The quiet of this car allows owners to hear sounds they had in other cars but didn't hear.
  10. liuping
    liuping Active Member
    San Diego
    I have the same issue (it sounds like it's just behind me on the left). If there is any cross wind, it sounds like my window is partly down (so much so, I usually reach for the window controls and make sure it's up all the way).
    I have a service appointment next week, so hopefully they figure it out.
    I also have a small amount of air coming in the little triangle window on the driver side. I did not notice it until is started getting a little cooler.
  11. N4HHE
    N4HHE Member
    Madison, AL
    Something I have noticed is that if I start the heater remotely from iPhone app when I reach for the extended driver's door handle (in my windless garage) there is a breeze coming out of the handle. Curious if this is related to the wind noise I hear from behind the driver? Agree its much worse in a cross wind.
  12. liuping
    San Diego
    My appointment got bumped up to today.
    They said the front left triangle window was incorrectly installed and they took it apart and reinstalled it. Unfortunately, it did not help with the wind noise. If anything it's a little worse now. I'm probably just more aware of it. (I drove home wight he stereo off, which I never do.)
  13. jerry33
    Texas
    Did they do the other wind noise fixes, or just the small window? The small window adjustment fixed mine.
  14. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    This is a known issue. A lot of the wind and whistling noises are coming from the front pano roof appliqué. This is the black rectangular plastic piece that sits between the front of the pano roof and the top of the windshield. Factory fix involves installing brackets underneath to pull the appliqué downward, creating a better seal. I had a very faint whistle, like a far away tea kettle, that was fixed.
  15. liuping
    San Diego
    They just did the small triangle window. I still feel a small amount of cold air coming in there, but it does not seem like enough to account for the noise.
    I have another appointment this weekend (to install my mysteriously missing trunk lights), so they are going to try again.
    I'm pretty sure it's coming from the b-pillar area. I can fairly clearly hear the tire noise of cars that pass as well, so something is not sealed correctly.
    I've also noticed some buffeting (like the low pressure thump-thump you get in some cars if you roll down just the back windows on the freeway, but not as strong) at between 40-50MPH. It might be the cause or an effect of the main window noise seal leak.
    I don't have a pano roof, so at least that source of noise is eliminated.
  16. jerry33
    Texas
    There are noise reduction fixes for both the A and B pillars if I recall correctly. The Service Centre here in DFW installed both without prompting.
    This happens with any car that is even remotely aerodynamic. It's the laminar air flow that is being broken repeatedly when you roll down the windows.
  17. liuping
    San Diego
    Yes, I've never experienced it with the windows rolled up before. I don't think it is normal for the Model S, but I could be wrong. I've only driven the test drive car and mine.
  18. jerry33
    Texas
    That's the hatch. (Sorry, I missed the windows closed bit). There are bumpers that you can adjust to put more pressure on the hatch and eliminate this noise.
  19. liuping
    San Diego
    Thanks, that's good to know. I'll ask them to adjust that on Saturday.
  20. SUPRKAR
    SUPRKAR Member
    New Jersey
