Left vs right makes sense for the solenoid block since left side shares a rail and right side shares a rail. We will see soon enough, though. I have the correct part en route and should have it installed by the weekend.Another pre-facelift car with SAS issues. I’m sure you saw my thread about the red icon/EAS_w007 error. Now I’m wondering if there’s some outlandish software issue with the last few releases. In my case, I’ve replaced the compressor twice. I never hear it running and I rarely even adjust the suspension. But something is causing it to run when I’m not “there” because after a couple weeks, the fuse will blow and compressor seizes again. This last time, I kept driving with the error and the car raised the back end to very high while slamming the front end. Anyway, don’t want to hijack your thread, but wanted to say that SAS errors may require Toolbox to clear in order for the system to work even after part replacement. With my last replacement, after powering the car on, the system kept emptying the reserve tank while having the compressor run and venting to the atmosphere. SC had to clear the errors and perform a suspension calibration for $35.
As for the solenoid block, I doubt that’s your issue since it’s a left vs right thing vs one corner now always dropping.
My suspension includes aftermarket parts, so a calibration would raise my car to standard height with lowering links. Don’t really want to go back to stock and then back to adjustable links, with two alignments mixed in.I second the re-calibration. That solved a few weird problems for me in the past.
Wouldn’t need to swap. What we’re saying is that Toolbox is needed to clear any error codes logged. The calibration sequence just goes through each corner and won’t care about actual height measurement. It’s all relative to each other, ie fronts match height wise.My suspension includes aftermarket parts, so a calibration would raise my car to standard height with lowering links. Don’t really want to go back to stock and then back to adjustable links, with two alignments mixed in.![]()
Share a rail? Didn’t think so since the block controls each corner independently. @Gtech previously posted the block diagram/schematic of the block and there were no shared rails. Either way, since you have the part coming, you will indeed know for sure.Left vs right makes sense for the solenoid block since left side shares a rail and right side shares a rail. We will see soon enough, though. I have the correct part en route and should have it installed by the weekend.
Unless they’re specifically looking for lowering links, why would they bother taking off the wheels? If you request a Ranger or SC to perform a 10min calibration, will they check to see if there are green links poking through the wheels?Yeaaaaaaaaaah but the service center won't do a re-calibration if you have aftermarket lowering links on
I'm having to spend 3x more on suspension components just to buy the ones with the T stamped in them so they'll still service the car if something else breaks.
Wouldn’t be surprised if you said yes, but just seems petty if so, especially if you’re not trying to get a warranty claim. Adjustable camber arms, etc., sure.
That’s supposed to be Tesla’s official stance on aftermarket parts.Yes they will. Or at least, the service center near me checks. And I'm not saying they just check to avoid it being a warranty claim, they flat out won't touch the car with aftermarket stuff on it.
Adjustable parts I can understand, but control arms, sway bar end links, etc. I wouldn’t think they’d complain about.That’s supposed to be Tesla’s official stance on aftermarket parts.
I have aftermarket adjustable toe, camber, links, air struts, and all links and control arms are aftermarket. I don’t even consider the service center.
Must also be location dependent because I told them up front I replaced the compressor myself, but the car still wouldn’t level itself. Tech cleared all codes and the car raised itself and leveled out. That’s when he did the calibration/reset. Sent me on my way for $235 (diag fee + cal) when they could’ve said the compressor and solenoid needed replacing.
Hope all works out for you Boston. You and Agg have had quite the suspension journey! Learned a lot I’m sure, just like me and the SAS issues.
I’ve had a few dozen hours of research done and it seems clearing any potential codes BEFORE swapping parts would be wise. I don’t have the dollars or patience to wait weeks for a service appt.Adjustable parts I can understand, but control arms, sway bar end links, etc. I wouldn’t think they’d complain about.
Rear camber arms prevented Tesla from messing with my car last year. Most recently my Model X wheels and a front spacer meant they weren’t allowed to level it or do an alignment, things I both really needed.I feel for @BostonBurley - my issues are brought on by my own OCD fiddling with stuff, he didn't ask for this nightmare!
In my experience, even for aftermarket control arms and end links - if you have an issue and there are aftermarket parts in the area, they'll blame it on aftermarket parts and refuse to work on the car unless you authorize them to remove the aftermarket parts and replace with OEM.
Most likely no. When you replace the solenoid you need to disconnect the 12v as well as the fireman’s loop so that’s as hard of a reset as it gets. Things could work fine afterward or any stored codes may prevent the compressor from behaving normally. That’s why we complain about Toolbox not being readily available/affordable. They need to release a Toolbox Lite where you can do simple things like clear codes.I’ve had a few dozen hours of research done and it seems clearing any potential codes BEFORE swapping parts would be wise. I don’t have the dollars or patience to wait weeks for a service appt.
But I need to do it. Resetting the car to factory settings, etc, will have no effect I presume.
Arnott never had them in stock direct so double check with Summit they will actually get them in early June.IIRC you have a nosecone car, right? If so, this one is beefier, and still a plug and play replacement:
Arnott Air Suspension P-3283 Arnott New OE Air Suspension Compressors | Summit Racing
Free Shipping - Arnott New OE Air Suspension Compressors with qualifying orders of $99. Shop On-Board Vehicle Air Compressors at Summit Racing.www.summitracing.com
RMT order a long time ago with struts never shipped, they didn’t seem to care when I canceled and went with Suncore, which I am shipping back this week. I don’t think I’ll deal with the Florida suspension rebuild crowd anymore as I had 3 of 3 failed experiences.Arnott never had them in stock direct so double check with Summit they will actually get them in early June.
An alternative that I used. Rebuilt, but worked fine. Great customer service since I had to get a second one thinking they sent me a bum unit.
Tesla Model S 2011-2015 OEM Rebuild Air Suspension Compressor Pump (6006403-00-A)
Find amazing deals on Tesla Model S 2011-2015 OEM Rebuild Air Suspension Compressor Pump 6006403-00-A. Order today and receive Fast Delivery and Discounted Prices!rebuildmastertech.com
