LOUD buzzing noise from front of new 75D
Discussion in 'Model S' started by jimmyz80, Aug 29, 2017.
Tags:
  1. jimmyz80
    jimmyz80 Member
    Apex, NC
    My S75D is about four months old now and just has a few thousand miles on it. Tonight it made a very loud buzzing noise from the front end while parked, that I've never heard before. This was after the car had been parked for hours in a cool ~70F garage, and then was briefly woken up by me opening a door. Anyone else ever heard this, or know what it could be?
    IMG 4356
  2. bktiger86
    bktiger86 Member
    West Covina, CA
    I think it is the fan near the left front wheels. I had mine replaced plus the AC compressor.
    This was the noise I had when I turn on the AC.
    • Informative x 2
  3. jjh1234
    jjh1234 Member
    Pittsburgh, PA
    Mine has always made that buzzing noise in my garage when I open the door and it wakes up and the A/C kicks in on high. If you have the A/C set on 70 and the temp is 75, it is trying to drop that 5 degrees as fast as it can. As an experiment, try raising the setting on your A/C to 75 and see if the noise goes away or at least lessens greatly.
  4. jimmyz80
    jimmyz80 Member
    Apex, NC
    It'd be weird if it was the A/C system, since I never heard this all though the summer months of 90s and 100s in the garage. It only now started doing it, and it's much cooler out there. Odd...
  5. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    Sounds a bit like what my LEAF does occasionally:
    Researching online led me to believe it was coming from the power steering pump.
  6. jimmyz80
    jimmyz80 Member
    Apex, NC
    There is no power steering pump in a LEAF, nor is there in a Tesla. :p I've owned a couple of LEAFs and I'm pretty sure the noise you're referring to is the coolant pump for the inverter/charger.
  7. JohnSnowNW
    Minnesota
    Yes, coolant pump/compressor whathaveyou. No idea why I wrote power steering pump...chalk that up to the headache I'm fighting.
  8. navinsiri
    navinsiri Member
    Central NJ
    That sounds exactly like the air compressor for the air suspension. It'll run for a few minutes once in a while and when it stops you should hear a small release of air
  9. 00poop6x
    00poop6x Member
    Houston
    Thanks for this video. Mine is doing the same interval step buzzing noise. Stops when AC is off. Warrantied?
  10. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    If it is not the AC then check the headlights. I had mine replaced for "buzzing" noises.
