Just took it to a service center to get it checked out. They said it's normal and only happens if I'm in drive or reverse, stationary, foot on the brake, and then turn all of way left or right. If I'm on hold, the loud creaking noise isn't there but there's still a slight squeak.
Not sure if it's actually normal or not or if they just didn't want to fix the issue for me.
Welp looks like I'm going back to the service center first thing tomorrow morning. Car is leaking a lot of blue liquid under the rear of the car: Model 3 leaking blue liquid near the rear
Took those pics earlier today and just went to go check again and the puddle is bigger
EDIT: No service centers are open over the weekend for me gotta wait until Monday morning. Probably not going to drive it at all over the weekend since this seems to be a motor/battery coolant leak
What an odd combination of issues. Did something hit the underside of your car relatively hard recently?
Any changes on the creaking issue?
I take what I said back. I'm able to replicate the noise in my car and it's simply the brakes rubbing against the rotors since the car is in Hold. When I mash on the brakes and turn the wheel, it doesn't make any noise.
Wow, my 2020 Model 3P does the same thing. The wheel is turned all the way right and foot on the brake and I get a loud creaking noise from the front right suspension. When my foot is not on the brake, there is no noise. I do not think that is normal at all. I made an appointment for the 23ed of this month. Hope they do not tell me it is normal.Just took it to a service center to get it checked out. They said it's normal and only happens if I'm in drive or reverse, stationary, foot on the brake, and then turn all of way left or right. If I'm on hold, the loud creaking noise isn't there but there's still a slight squeak.
