Loud squeal while braking to a stop -- video attached
Ed Chan
126
2
Palos Verdes, CA
I recently had my brake booster replaced in my autopilot-able S85, as requested by Tesla. Since then, every once in a while (so far 3 times in 2 weeks) I've had this strange noise when braking close to a stop, and a very high frequency vibration coming from my steering column as well. Any ideas? I'll probably bring it in after the holiday for them to look at...
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
198
Any lights or warnings? Could the car have thought you were coming close to colliding? Or perhaps it's detecting the red light as part of some future SW enhancement and it's mistakenly activated in yours haha. Either way, sounds like something is up with one of the AP sensors (or software)
PlanB
Banned
Oct 4, 2014
570
3
Oregon
Next time you might want to turn the radio down. Also, that is not abnormal my car does it as well, it's the new bigger brakes and the dry pads. Mine does it when it's hot and dry out.....sometimes when it's rains but not as bad.
Todd Burch
Voltage makes me tingle.
Nov 3, 2009
7,827
28,735
Smithfield, VA
What new bigger brakes? I have a recent build (P85) with over 2,000 miles on it and I've never heard that sound. 35,000 miles on an early Tesla and never heard it either. That is absolutely not normal.
Sounds like the rotor is vibrating (also explaining the slight vibration in the steering wheel)...should be fixable.
scottm
Legacy account
Jun 13, 2014
3,070
2,234
Canada
I get brake squeal that sorta sounds like that at slow stops.
remember, brakes are for inefficient drivers, regen rules!
That sound is my penalty reminder that I should not be using brakes.
Ed Chan
126
2
Palos Verdes, CA
I don't think it's normal.. It was VERY VERY loud, and like I said before, it made the steering column vibrate... My service advisor noticed my post and contacted me and they'll take a look at it after thanksgiving, since i'm skipping town on wednesday.
@scottm - Regen can't bring your car to a stop, so unfortunately, brakes are still required :)
Kbsilver
134
0
Central NJ
That sounds like typical brake squeal, essentially the brake pad vibrating at a high frequency during braking. It is often necessary to apply an anti-squeal compound to the back of the brake pads to stop this. Whenever I replace pads I either use the compound supplied with the pads or apply high temperature anti-seize grease/compound to all the metal to metal contact points of the brake pad. I've never had a squealer using this method.
rdrcrmatt
607
31
Milwaukee
Bike brakes squeal as well, but usually a higher pitch than that. the resonance frequency of your wheel, brake rotor / pad combo must be different than my car (P11xxx - P85, 19").
Most of the squeal we get is due to the lack of use of our brakes.
linkster
1,128
267
USAX2
You may consider performing a quick visual check just to insure that the plastic anti-squeak shims (two/caliper) did not get missed during the Brembo assembly procedure that can be verified without wheel removal. They are located by the brake pad cross pins along with several clips (two of which can be easily seen at the top of the caliper). The top clips/tabs are inside the pins on the front calipers and outside the pins on rear calipers and fit snugly between caliper pistons and brake pad metal backing plate.
ArtInCT
Always Learning
Sep 2, 2014
1,713
433
Southern Connecticut
If the noise pops up just before your vehicle comes to a complete stop (as it did in your video), as opposed tosquealing throughout the entire range of braking, the cause could be a brake pad that is vibrating against the rotor. A set of brake pad vibration damper pads /shims / lubrication could cure the squeal, but there's no guarantee. Also some brake assemblies have a wire spring on each pad that tries to pull the pad away from the rotor when the brakes are not used. These springs can be missing or not attached correctly due to recent work done on the car or some other mishap. If the springs / shims are wrong, your pads could have been rubbing slightly on the rotor and perhaps have become glazed. Glazing on the pads can cause the squeal and vibration when applied. Glad you got an appointment and will be getting them looked into by your SC.
Another cause of squeal is a wear indicator that is inbeded in the break pad itself. As the pad wears out it reveals a metal tab which emits a very loud squeal as it rubs against the rotating rotor. I do not think this is the case in your instance as the squeal was more towards the end of the stop.
Also, if you get new break pads as a part of the fix, do some research on breaking in new pads. There is a procedure to mate the pads to the rotors which is easy and somewhat fun.
