Loud "thunk" coming from driver side somewhere?
dsnows
211
167
Winchester, VA
On my way to work today, I slowed at a stop sign and heard, maybe even felt, a "thunk" like something had hit my car. Sounded or felt like a ball or bird or something. Not like a rock. I got out and checked the side of the car, and saw nothing. A mile or so later, stopped at a red light in traffic and same thing. Seemed like it was coming from the driver side door. I thought maybe the doorhandles presenting, but doubt they would be that loud. Any ideas? it was enough to startle me. I really thought something had hit the car.
cgiGuy
1,500
1,082
Everywhere, Nowhere
Loose brake pad?
Bowling ball in the frunk?
Krypto Kat
108
124
Pittsburgh
I've had similar experiences in Gas cars, it is usually the sound and feel of clunky multi speed automatic transmissions getting foiled by driver inputs.
In the Tesla it maybe suspension / control arm issues?
scaesare
8,187
12,928
NoVA
So I'm getting a clunk in my drivetrain. You can feel it in the chassis.
The service center tells me its an axle bearing assembly issue (but not necessarily the bearing itself).
What's disconcerting is that it happened IMMEDIATELY upon receipt of my car after yet another drive unit replacement. It went from no issue to significant literally overnight with repair in that region ...
dsnows
211
167
Winchester, VA
Does your "clunk" seem like what I'm describing? I've had the car for 6 weeks and today was the first time I heard this. I only drove it about 2 miles to work and it happened twice. Several other stops with no "thunk". Does yours happen regularly?
dsnows
211
167
Winchester, VA
I'd first make sure you don't have any loose items in the car.
If you still hear the thunk, is it from the front or back? By the tires?
I'll check for loose items, although I don't think that is it. And, it seems to come from the drivers side either front or rear door. But not sure I have it well localized.
TrevTremaine
975
544
Toronto, Ontario, Canada
Is the suspension raised? I had some clunks come from the front whenever I accelerated hard and the suspension was raised above normal. Dropped it down, and it went away. That said, it was noted that it could be a control arm. Never had it investigated though.
SMAlset
8,732
9,338
SF Bay Area
Were you decelerating kind of quickly at the stop sign/light? If we go with the something shifting, could it be that heavy iron towing eye maybe stored under your seat or in the trunk area? I know the newer model S has a towing eye that is bigger than the previous version and doesn't fit in the UMC bag so wondering if maybe yours got put under your seat or is "floating" around in the trunk and was sliding around. It's pretty heavy and I've read about people commenting they could hear it hitting around in their trunks when not secured in there.
Would the control arm give off an alert if something was wrong with it?
ig_epower
183
198
Oakville
For me, it was the plastic cover of my seat-belt that hit against my seat. The culprit was located on the lower left side of my seat between the seat and the b-pillar near the floor. I covered it with felt as suggested by the TMC posting and now the sound is gone!
radio
16
7
Vienna, Austria
I hear that sound sometimes when suddenly Auto braking engages for a second due to wrong AP inputs (overhead signs, in tunnels, adjacent much slower cars). I relate that to the braking system or brake pads and don't worry at all as I relate this to the very quiet car environment.
GJ79
266
89
Tampa
Is it you AC compressor kicking in? Mine does that too and I can hear it loud and clear inside the car but when trying to hear it from the outside it's just a very quiet click.
Reactions: JohnnyG
