Love Field parking
Discussion in 'Texas' started by Boourns, May 29, 2018.
  1. Boourns
    Boourns Active Member
    Dallas
    We're taking a trip this weekend from Friday to Monday. Given that it's going to be so hot and you can't turn off cabin overheat protection in the 3 yet, I hesitate to take the 3 and leave it parked all weekend just to run the AC all day.
    I see that Love Field has EV parking. The website explicitly says they are OK to use while traveling, but that runs contrary to my public charging etiquette instincts. Anyone have experience using it? Are there usually spots open? Would it be an a-hole move to park there all weekend?
    Dallas, Texas Love Field Airport
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Assuming it’s the same as in the S and X, cabin overheat protection is disabled if the battery is down to 20% charge. But over a 4 day weekend you’d never get that low anyway. I wouldn’t worry about it.
    Airport parking lot charging stations are meant to be used by people taking trips. That’s the only reason they are there. If there’s an open spot, no reason not to use it. Consider airports as the exception to the usual EV charging etiquette rules.
  3. bollar
    bollar Disgruntled Member
    Southlake, TX
    I salute your great instincts re: airport charging. I think you're safe over the weekend without charging.
  4. chris5639
    chris5639 Member
    Dallas
    A while back there was a start up installing L1 charging at airports. Not sure whether that took off or not but I thought that was a great idea for the airport parking use case. A lot easier to provide more charging spots @ 120V and 15-20 amps.
