Given my daily trips are only around 25 miles and only using about 10% of range, any reason not to do my daily charge at 240V/ but lower amps to make it easier on battery?
I have read a post from an owner who did a study that showed that charging efficiency is the same at 240V/24Amps as 240/12Amps. Given I am typically charging from 55% to 65% or so on a daily basis, and time to charge is no concern, why not charge the few hours my refill takes at 12-16Amps/240V (less than my house capacity of 24Amps) to be gentle on battery for my typical daily cycle? Lower amps are less heat, right, and heat is one of the enemies of battery charging, correct? Thoughts?
