Low Charge Speeds and Poor Maintenance
Discussion in 'Supercharging & Charging Infrastructure' started by Cfinck, Jan 5, 2020.
  1. Cfinck
    Cfinck Member
    Santa Monica
    Hi everyone,
    I recently stopped at the Rancho Cucamonga Supercharger in SoCal and 5 of the chargers were out of commission for one reason or another being broken. I waited and hopped into a stall after someone else was finished and then only was hitting 37kw max at the 150kw charger.
    Are people intentionally sabotaging these chargers in retaliation or are tesla owners not taking care of them?
  2. Watts_Up
    Watts_Up Active Member
    In a galaxy far, far away
    How do you find out that they were not working?
    -Warning sign and or yellow tape around the charger
    - Message on the car display
    - You tested each one by one
    Didyou noticed any visible damage?
    - plug damaged
  3. motocheme
    motocheme Member
    Murrieta, CA
    That site is very popular and in constant use. On multiple occasions I have seen them out of service due to people running over them etc. I have not seen 5 of them out though!
  4. mociaf9
    mociaf9 Active Member
    37 kW is about right for the second car to plug into a paired stall on a 150 kW supercharger. Since you mentioned that you were waiting and only got a stall after someone else left, it's most likely that your stall was paired with a another where that car was getting the full rate and yours did exactly what it was supposed to and operated normally.
  5. Cfinck
    Cfinck Member
    Santa Monica
    Two of them had the white and red covering just cracked open and damaged. The other three had the chargers thrown over the top and we tried them with no success
  6. IronQQQ
    IronQQQ Member
    I live in Rancho and I go to this SC about once a week. The site has been getting worse and worse. I would say 3 to 4 broken is quite common with low charge speeds for working stalls. I've plugged in to get 5 kW for over an hour. I've also gotten plugged in and served 0 kW for several minutes, and stalls refusing to start session, stalls disconnect when a neighbor plugs in and it goes on and on. The site is very heavily used and often a line on weekends all day and lines during busy peaks hours on weekdays. 10/12 stalls filled at midnight is not uncommon. It is not vandalism.
    The build out of 24 urban 72kW urban chargers just a few miles up the road in Fontana has not relieved Rancho. Rancho is almost always slower than Fontana even though Rancho is 150 kW site.
    Today all day the site was at reduced service so in decided to check it out. 6/12 are broken and there were zero cars there. I have never never ever seen Rancho with ZERO cars (my car to the pic is not plugged). Usually even at wee hours of 3 or 4 am there will be a couple of cars plugged in.
    3 weeks ago I really needed a quick top up to get to 80% SOC. I pulled a whopping 9kW. After a few mins, I left when they speed didn't increase. I didn't bother trying another stall as this was the 3rd stall I tried and a line had then formed. I went home and charges at 8 kW. How super when it is only 1 kW faster than my garage?
    Reduced service today
    13 kW
    5 kW
  7. ATNX143
    ATNX143 New Member
    It’s been a very bad week at the rancho station smh
  8. IronQQQ
    IronQQQ Member
    Went by VG today on my weekly visit. 5 stalls down, 5 car queue, even saw an X with towing a trailer heading there. I wanted to scream at him, go to Fontana instead ! You can parallel there and not to have wait only to get served 20-30 kW!
    Interestingly the car nav said 2/12 available.
  9. dgatwood
    dgatwood Member
    Sunnyvale, ca
    Yesterday at Mountain View, after ten minutes, my charge speed (at 60% SoC or so) had dropped to only 25 kW while alone on a pair.
    Apparently the V2 Supercharger stations have a high failure rate from overheating if they get used continuously. I’ve had approximately zero problems in Gilroy and Salinas, but nonstop problems in Mountain View and Sunnyvale.
    They really just need to replace all the high-use stations with V3 racks and cap them in software until they can up the available power....
  10. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    Did you report these problems to Tesla?
    How about also checking into Plugshare (presumably PlugShare - Find Electric Vehicle Charging Locations Near You) and adding photos of the problems? For Tesla Superchargers, arguably the first part's more important.
