I am looking at using a PowerWall2 for essential circuit backup.
One of the circuits is a freezer which has a power factor of 0.60 and running amps of 2.0. This means energy use is 240 volt-amps (VA) but only 144 watts (120v * 2a * 0.60pf).
So, in theory should the freezer run 91.7 hours (13.2kWh / 0.144kWh) or 55 hours (13.2 / .240kVA) on a single PW2 charge? Or, are both of these wrong? Let's just focus on the difference between real (W) and apparent power (VA) due to low power factor and ignore duty cycles of the freezer, battery/inverter efficiency and the like.
I wouldn't have questioned using "real" watts until I saw this in a PW2 spec sheet:
1) Capacity is 13.2kWh of AC Energy
2) Power Factor Output Range is +/- 1.0 adjustable
3) Power Factor (full-rated power) of +/- 0.85.
Number 3 especially has me puzzled. Can anyone provide clarity? I tried Tesla sales, hot line, and their forum to no avail.
Thanks.
Thanks.
