Low Tire Pressure warning
I keep getting low tire pressure warning from rear right tire. when I try to get it repair, the tire shop said my rear tire is worn out so I replaced them a month ago. ( all 4 tires) Now after 2500-3000 miles, i had the same problem again at the rear right tire. Any idea what may be the cause of this? The tire or the sensor?
Checking it with a $5 pressure gauge should answer your question. Check in morning after letting it cool. Correct pressure is indicated on drivers door jam.
