Have any of you that lowered your cars taken them into Tesla Service yet? If so, what did they say about it?
Not a thing. One guy at the service center did say he really liked the look of it lowered.
Hi Guys
Rick and Todd have raised a concern about the length of the front 'Evolution' adjusters and the provided adapters as a result I have withdrawn the product from both eBay and our Website.
I will be work with Rick, Todd and Ari to address the matter and find a solution which I initially believe will achieved by producing a shorter adjuster which would negate the need for the adapter.
After discussions yesterday with our employed engineering company I have furnished them with the design for the new adjusters which they have suggested they can produce within four weeks.
I will be sending the amended front adapters FOC to the guys above for their review, testing and approval.
As a company that prides itself on producing the best kits on the market we will ensure this matter is resolved quickly and efficiently.
Please do not hesitate to contact me regarding this matter.
Kind regards
Mark
Can anyone be specific as to the issue? Pics?
I don't have photos but the issue was that the front links, set to the shortest possible length, were still longer than the stock front links and would have lowered the car too much. I dealt with it by using a hack saw to cut the link body and one arm about 3/16" shorter, which then made them about the same length as the stock front links. With that done I could then calculate the proper length and final settings to lower the car to my target level. The work was pretty simple and, as I thought they had mixed up a front link from a different car with my order, I didn't make a big deal of it. But I did let Mark know, as did Todd. Thus Mark's message. I told Mark what the stock length of the front link was and he's working with that number as he redesigns the front link.
Can you clarify if these modifications were done prior to the photos you posted? I guess what I'm curious about is--- the photos you posted of the links installed and the car at LOW height--- were those after the modifications you made?
Mark was nice enough to CALL me all the way from the UK to USA today, just to explain all of these details and offer various options. Based on our telephone chat, I think that I am going to proceed to install the links as-is. It is my understanding and "estimated measurements" that 35mm drop will not be too aggressive for me. Frankly I think it will be perfect for driving all the time. Chances are good that I'll never be able to use the low setting other than to park the car (cosmetics)-- and Normal will become my permanent ride height for driving. We'll see...
But I just wanted to verify that the drop shown you have I assume is "post" hack saw cut? Your height looks perfect to me for "permanent driving" ... so I think that I might be okay if LOW for me is even lower than what you show there, because I can just drive in Normal mode.
Yes, the photos show the car lowered post hack saw shortening of the front links. The link lengths were set to 70.75 mm front and 86.5 mm rear before they were installed. So if you can set the front link length to 70.75 without having to cut it, great. You'll achieve the same effect as I did.
Here's the ground clearance data:
So there's a 9mm difference between normal and low.
Inches MM
Very High 6.4 162 High 5.9 149 Normal 5.1 129 Low 4.7 120
Inches MM
Anybody try this guy's links?
Tesla Model s Air Suspension lowering Links Module | eBay
He says the links can only be adjusted in length by popping off one end. Sounds like a good idea that they can't turn and self-adjust while on the car over time.
- - - Updated - - -
stock, or after your new settings?
Anybody try this guy's links? He says the links can only be adjusted in length by popping off one end. Sounds like a good idea that they can't turn and self-adjust while on the car over time.
Yes, you have to cut of about 3/8" from one end of the link body with a hacksaw to make the front links short enough to use. Mark is creating a new front link that won't require doing this. He expects to have them in about a month and will repost on TMC. These are nicely made. He sells them for a lot of other vehicles as well.
Here's the stock ground clearance data:
Inches MM
So on the highway the standard height setting will be it for me: park and low speeds in low height, highway speeds in standard height.
I see the need for more settings in the auto-lowering functionality speed settings: Low at low speed, standard otherwise.
I was thinking the same thing, but I doubt Tesla will accommodate us
What's interesting about this is how various height settings affect tire wear. I'm guessing that owners who have the longest lasting tires may run the car most of the time at standard height or higher.
