Lowering an M3P stealth
Discussion in 'Model 3: Driving Dynamics' started by Ryansgt, Mar 5, 2021 at 1:29 PM.
  1. Ryansgt
    Ryansgt New Member
    Lake Villa
    Hi guys, I've had her for since november 2019. Thinking I'm gonna drop it a decent amount. I was looking at the UP moderates, not sure if they would even work for the stealth since they seem to jump to the UP super performance if you select m3p but moderate if you do LR AWD. So obviously it's p motors but 18's and lrawd suspension and brakes.
    Input need on this spring/dro height and if going to a coilover is the only way to avoid messing up the camber
    Also considering the bc racing coilovers since they seem to have a reputation as a decent priced system.
    I'm not going to be tracking it at all, literally just looking for a lower ride height for aesthetics, efficiency, etc. I don't want to go low enough to scrape every curb. also probably going to upgrade to the pilot sport 4s as well and i really don't want to chew through those by not being able to adjust the camber.
  2. ishulai
    ishulai Member
    Irvine, CA
    From my experience, either go UP springs or MPP coilovers, depending on your budget. BC coilovers are just eBay garbage with a brand name. I’ve had the UP moderate and low springs and I’m currently running MPP comfort adjustable coilovers.
    I have the stealth. Definitely get suspension/brake parts for LR AWD instead of performance, since you have the standard suspension (motors don’t matter in this case, since it’s just a software tune).
    Coilovers won’t prevent changes in camber at all. If you’re just driving it on streets, you don’t need to worry too much unless you’re slamming the car. If you do care about the camber difference, you’ll need to get aftermarket camber arms (MPP, UP, and SPL all make them), but I don’t think it’s needed at all unless you’re actually tracking the car.
