Lowering kit for a Model X
zanardi43
22
15
Upstate NY
I just got a Model X P90D and I'm already wanting less wheel well gap...thinking it's time to lower it. I've been lucky to own quite a few high-end performance cars over the years and I've modified every one from mild to extensive. I've never had air suspension though and obviously have no plans to track my model X, so this time lowering is just about aesthetics. Anyone have experience with this product from Unplugged Performance?
Sports Air Suspension Lowering Kit for Tesla Model X - Unplugged Performance
If so, I'd be very appreciative of advice.
Thanks
Reactions: hiroshiy and Cowby
bushburner
327
207
new orleans, la
The suspension on very low looks good to me, but i'm guessing you want it to almost tuck. Post pic when you do get the kit and also aftermarket rims are a must unless you are already on stock 22s.
Pwdr Extreme
317
547
Bozeman, MT
Sounds like all that kit does is reposition the ride height sensors. Seems pretty expensive for what probably amounts to a few pieces of metal, more or less. You would definitely need to get the car completely realigned. The camber is already far off enough to cause uneven tire wear on the very low setting, this looks to go an inch or two lower than that.
I'd bet if you had a suspension or drive train problem, Tesla wouldn't cover it, as the parts aren't designed to be operated at those angles. Most likely they will still cover the FWD's, interior and computers, etc.
Reactions: Big Earl
zanardi43
22
15
Upstate NY
I've since decided not to lower my MX. Instead, I had the alignment adjusted while in the VERY LOW setting and figured I'd drive around like that for a while to see if I could live with the wheel gap being not great, but better. I was very pleased (and surprised) at how close to OEM alignment specs they were able to get even in that lowest setting. It's been 3-months now and I no longer have plans to lower it.
ridersinc
Alien from another planet...
Dec 2, 2016
63
48
Los Angeles
I pulled the trigger last night...had @UnpluggedP handle the install. So far so good.
Cheers Nicolas
skilly
748
216
Livermore CA
what Im confused about is why not use lowering links like the Model S? They are half the price and allow some flex into how much you lower it. The brackets being 500.00 seems really simple but more expensive - does the suspension not use links for the Model X?
skilly
748
216
Livermore CA
Links work but the lowering bracket is a better solution. The links for the X in the front are so long to lower that they compromise the integrity of the system. There is much higher risk of them popping off their mount and having a failure. I would use the brackets - its a much cleaner system that just changes the mount position to get the same results.
Toddl
37
7
Glendora
Skills thanks. do you have experience with either one. Sounds like you may have done some research since August ?
Toddl
37
7
Glendora
Jchris and Nicolas, I would love to have your opinion . How much is the car lowered.? Also I have asked a couple tesla folks and they say that the car already has adjustable suspension, so why not just leave is on low? what would you say to that? Thanks!!
BLKMDL3
1,786
1,102
Westwood, Los Angeles, CA
I did it last month. Looks so mean. Getting new rims soon so mind the 20's. I plastidipped all the chrome myself to give it a stealthier look and tinted my windows dark. lowers it by an inch or so. It was worth every penny.
Toddl
37
7
Glendora
Very cool. How did you do the plastic dip. ? Can you pull the Chrome pieces off easily. I would like to do the front and rear for sure
ridersinc
Dec 2, 2016
63
48
Los Angeles
I believe exact lowering specs are on their website. I go low over 55 and super low when parked because sometimes “low” just ain’t low enough.
