Lowering Links Install
Technupe
50
10
Boston, MA
Hey, just wanted to share that I installed bloc lowering links on my model x. Took a couple pics/videos that I hope to share. Didn't find much content on lowering links online, especially for the model x. Really easy! I say if you can change a tire you can install links. But you have to be patient to ensure the adjustable links are the correct length. Also removing the stock links require some patience.
Car is sitting really nice on low. The attached pic was right after I let the car adjust the first time. Over the day the car height increased a tiny bit but looks great.
Reactions: VikH and z168
sacfan
183
74
Sacramento
Please tell us what bloc lowering links are and how they work. I appreciate the end result but how was it done? Thanks.
Technupe
50
10
Boston, MA
Adjustable Lowering Links :: Tesla Model X
Links are a piece of rubber (atleast mine were) that are a set length, they are attached to a sensor in the air supsenion. The set length let's the car know when it's reached the preset air suspension settings. The aftermarket links can trick the sensor due to the links being a different length than stock. There are preset size aftermarket links and adjustable links. The adjustable links allow you to customize to your desired height (up to the limits of the car)
The attached images show:
1. The stock link (held by plier, I already took one side off). (85 mm length)
2. The aftermarket link measurement 8.1mm longer ( I couldn't get to exactly 8)
3. The aftermarket link installed
You repeat this step for each wheel. The rear wheels have to be removed, the front can be changed while the wheels are still on. Car has to be in high/very high then jackmode before you start the change. I'll come back and provide detailed steps if anyone is interested.
sacfan
183
74
Sacramento
Thanks for the clear explanation and the outstanding photos. As an older (though likely average age due to the cost) Model X owner, I gather the intent is to have the vehicle ride as low as possible for appearance-sake. I bought the Model X partially for the opposite reason: to raise it up high or very high to help clear the snow in winter. When you lower the suspension way down, don’t you run the risk of bottoming out and damaging the battery and other components under the car?
Yinn
2,079
1,857
Behind you
The lower the car, the more risk of that yes. The lowering links lower up to 2 inches IIRC. The stock clearance is 7in so that puts it at about 5 in if you choose to adjust it that far.
The normal ride height of a Model S is about 5.3” so the clearance would be about the same.
Although there are concerns around dampening rates, alignment/camber, and suspension travel still.
The further you go, the larger the concern. A minor drop probably wouldn’t be a concern at all, especially if the goal is to just leave it in “standard” to ride in “Low” so that one can still get speed based adjustment to get to very low at highway speeds.
Technupe
50
10
Boston, MA
Yes, mostly for appearance. However, I tend to have my car on low most of the time. Now it'll be on standard most of the time, and very rarely drive on very low. Definitely do not want to affect/impact the battery.
VikH
941
770
Midwest, USA
Looks good! I really considered doing this, but was already getting a lot of camber wear on stock Low. Unless you get a camber kit, those puppies will be toast in no time.
Apr 7, 2020
54
40
Houston
If you set it right you can ride at the standard setting but be a little lower, though not all the way down to stock low. This lets you cheat and get an in between setting. You get a lower low for looks when you want, a lower standard for looks and better aero all the time and loose a little on the higher settings.
Reactions: Technupe
bionichomer
86
59
Atlanta
How much of a drop did an 8mm longer link provide?
