mact3333
I only plan on keeping M3 long rage dual motor that I bought this past weekend for only 2 years, otherwise I'd be all over lowering this car...might do it anyway...tempted.
Forgot to mention these are rear wheel drive springs, not sure if they sell AWD ones, but they are advertised at 1.2 front 1.2 rear.
View attachment 397693 View attachment 397697 View attachment 397698 View attachment 397699 View attachment 397700
Most cars (including the Model 3) have the appearance of "reverse rake" stock because the fender opening is taller in the front than the rear.
Lowering the car makes this more noticable.
The best way to measure ride height before/after is from a fixed point on the chassis. Failing that, measuring from the top of the fender opening to the center of the hub or the floor are acceptable ways of measuring ride height.
The Tsportline AWD Performance springs is 1” front and 1.2” rearLooks good, yeah the Performance AWD is 1.0" front and 1.4" rear. TSportline and UP offer the same drop front and back on AWD Performance, so I'm really curious why Eibach made such a difference, and I'd love to see pics.
While not on their configuration wizard, they do exist:
PRO-KIT Performance Springs (Set of 4 Springs)
Do you have a P3D? I have one and haven’t noticed a difference in gap size on the front and rear. I’ll have to take a look later.The stock gap is certainly larger in the rear than in front.... At least on my specimen.
Looks perfect!!! Do you know the weight on the wheels?Good eye! Thanks - they are the 19x9.5 ET40 (no spacers) with Continental DWS06 265/35R19 - range may take a hit, but I haven’t been hypermiling.
View attachment 397270 View attachment 397271 View attachment 397275 View attachment 397276 View attachment 397279 View attachment 397280
Thanks. I didnt have a chance to weight them, but they should be about the same as the stock ones at around 25lbs. Would probably have to go forged instead of flow-formed to get lighter.Looks perfect!!! Do you know the weight on the wheels?
What's the biggest disadvantage to lowering the car?
People are gonna stop you and ask what’s different about your car... because it looks so good and sporty. Is it one of those performance models? So if you’re in a hurry that is gonna slow you down.
I have yet to discover any disadvantages, only positives, but again that’s just me.
It is shocking how much just an inch or so of lowering changes the overall appearance of the car drastically.
What has been seen, can never be unseen.My Model3 with race wheels ready to go!
I purposefully have my track wheels smaller than stock, so definitely looking to lower! problem is I want to be able to also fit my 20" wheels. and be able to actually get a jack under the car....
Those red wheels
A lot of these photos look like the car has reverse rake after lowering. Is it just the camera, or does the car look like that in person? It's my #1 reservation...
I have a non lowered (yet) M3 LR AWD with the 18" stock wheels and yesterday I accurately measured the wheel gap at the front and the back.
Front: 5,9mm (2,32 inch)
Back: 6,6mm (2,60 inch)
So stock, the front is lower than the back. Like it should be. At least, on an AWD!
The car of @BAven8068 certainly looks a little lower at the back. I dont know if that already was the case when you got it...
Maybe Tesla uses the same springs on a RWD and AWD and since the AWD is heavier in the front it is a little lower there.
just my 2 cents of thought...
Potential scraping on driveways, speed bumps, dips at intersections, and bumper stops. I have to take my driveway approach at an angle or else my stock height 3 will scrape. City will not let me modify my driveway approach because it is city ordinance to facilitate drainage. YMMVWhat's the biggest disadvantage to lowering the car?
I never measured the car when it was on stock springs, but I do know that both gaps were awkwardly large.
I think the appearance of the rear being lower on the aftermarket springs isn’t really the case. The car overall seems level but to me the front fender opening is just larger therefore giving it the look of being higher.
What about just measure it like I did?
Just put/slide a strip of straight metal flat on top of the tire and make it stick out enough. Then use for example a caliper to measure the distance to the car.
