Funny thing: here’s my graph - note the dip around 12k miles and the recovery. But I did absolutely nothing to “fix”it. No deeper than usual discharge, no higher than usual charge limit. View attachment 454379
I generally charge to 75% and avoid going below 20% but charge to 90 or 100 when I need the range. I never let the car sit at extreme charge levels (high or low) for any period of time.
When I need range I have gone as low as 3% but my daily needs are about 50 miles so I try to be gentle on the battery.
I'll try re-balance if I ever encounter a range issue. For now, I follow the manual: charge to 80-90% daily and keep plugged in all the time at home. I will supercharge on road trips.
Sure. Charge limit is set to 82-84% on weekdays and 90% on weekends (that's when I do most of my driving). Typically charge at home from a 30 amp outlet and the car is almost always plugged in when I'm not driving. Charge to 95-99% 1-2 times a month and make sure to drive right after I stop charging if I go above 90%. Supercharge 10 times a month or so, usually to 80-85%. So, in other words, nothing unusual.
Thanks for both of your answers. Mtndrew's charging seems very conservative, charging to 75%; while ilyak's is usually conservative, 82-84%, but a little more aggressive use of supercharging. The only commonality is both keep their normal charge limit near 80%, between 75% and 84%, as opposed to charging up to 90%.
I used to charge to 75-80% regularly. And then of course it was suggested that I should be charging to 90%. I did that for about three months, and of course there has been no benefit.
I think that the idea of the slowly permeating call to set the mark at 90% is not that there will be any benefit per se, but rather that it doesn't do any actual harm.
I believe that the 90% thing originated from Musk in a tweet about unbalanced packs showing reduced range.
If I start off by telling people that I charge to 90% all the time, they tell me that perhaps my problem is that I'm charging too high. If I start by telling them that I charge to 80%, I'm likely to hear that perhaps my problem is that I'm not charging high enough.
Or that I should go to 100% and 10% more often. Or that I should do it less often... you get the picture.
