Maybe older cars are not as susceptible to this issue for some reason?
Lucky you. Don't know if your car switches to Wifi in your garage. Mine does because 3G signal in my neighborhood is very poor. Almost every other morning, the car will not reconnect to 3G after leaving home. Rebooting the touchscreen fix it. My SC suggested deleting the Wifi setup to maintain the 3G connection and with always ON. It did not help. I hope there will be a fix to this from Tesla soon.Still curious to know why I don't seem to have the problem nearly to the extent of others. I've had maybe 5 dropouts in 2.5 years, and I'm in the car a lot. I have no problem whatsoever when my car flips over from WiFi in my garage to 3G as others have reported. The only time I have had a dropout as described by others here is when I'm in an area that I don't usually frequent, and that's why I think it has something to do with signal strength or the cell tower you're connected to.
I don't know how best to explain it, except I know that at the same location where the 3G signal is weak, rebooting the touchscreen fixed it. Does it mean that rebooting initiates some sort of authentication with the service provider that the car does not do when simply switching from Wifi to 3G?I'm not convinced it's an issue with the car. If it was, why wouldn't people have problems in other countries? It has gotten better and worse over time, and maybe that's correlated with software upgrades, but I'm not sure that's 100% proven. I can't say I know what the problem is and I haven't seen any real evidence of a solid pattern. It did seem better with Power Save off, but it's random enough that that's not conclusive in my mind. This is why I think Tesla needs data - the logs probably say a lot more than we can see, like what specific network or cell technology or maybe even cell tower it was connected to when it dropped, where it was when it dropped, what it was trying to do to re-connect, why that wasn't working, etc.
Yes, it does. The only thing I notice is a 1 or 2 second pause in my Slacker music about a block from my home. I think it's because it buffered so much on WiFi and then has to start streaming on 3G after the switchover. Maps and everything work fine, and my 3G symbol come on immediately after the WiFi symbol goes away.
Here's (loosely - there are minor differences between vendors, and I'm simplifying) what happens when you lose coverage.I don't know how best to explain it, except I know that at the same location where the 3G signal is weak, rebooting the touchscreen fixed it. Does it mean that rebooting initiates some sort of authentication with the service provider that the car does not do when simply switching from Wifi to 3G?
Don't you have always connected checked with energy saving set to off? That seems to make the dropouts much much less for me, although to save energy I have it set to the opposite.
Is there a retrofit ? I didn't think they were offering one?
At Tranmere? I called Lawrence last week and they didn't know that a retrofit even existed. I will get this done but will likely do the Ludicrous and LTE at the same time if possible.I am booked for the install on Aug. 24
Yes MississaugaAt Tranmere? I called Lawrence last week and they didn't know that a retrofit even existed. I will get this done but will likely do the Ludicrous and LTE at the same time if possible.
