Lubbock Supercharger
Discussion in 'Texas' started by timpierc, Dec 17, 2016.
Tags:
  1. timpierc
    timpierc Member
    Broomfield, Colorado
    Lol I'm from/grew up in Lubbock Texas. Only way you're going to get EV chargers set up there is if you can convince a business owner it'll make them money. Given the amount of pickups and tahoes/suburbans everyone in Lubbock drives, it's not a high possibility to say the least.
  2. reddy
    reddy Member
    Amarillo, TX
    The Overton Hotel in Lubbock now has Tesla destination chargers. If you plan on staying in Lubbock overnight, this is a good place to be.
  3. xlpro
    xlpro Member
    Lubbock, TX
    Yes sad I agree. Tesla has really dropped the ball on this one. The map showed 2017, then 2018, now it's 2019 and still no signs of a supercharger. Well anyway if anyone passing thru needs to charge I have 2 HPWC (240VAC @ 80-amps - 19.2 KW) come on by. I've had about 20 Teslas charge so far. I'm on plugshare. Call or text.
    Anson (806)441-4354)
    • Helpful x 4
  4. Rmk1
    Rmk1 Member
    Lubbock, Tx
    Looks like the Holiday Inn express in spur 327 has tesla destination charges. Can see them from the access road. North end of the building. Audi dealer also has free chargers that look to be available all the time,
    But no sign supercharger yet in town.
  5. reddy
    reddy Member
    Amarillo, TX
    Checked on permits today, still nothing .......
    • Informative x 2
  6. HillCountryFun
    Texas Hill Country and Denver, CO
    Very sad, thanks for checking
  7. xlpro
    xlpro Member
    Lubbock, TX
    This getting ridiculous! However whenever we do get it, it should be V3!
  8. Zella
    Zella New Member
    Amarillo
    Looks like this Supercharger has been scheduled to be installed since 2017. Is there anyway to know an approximate time frame? I live in Amarillo but Drive to Lubbock 3 times a week. I do have the long range model 3 but at 75 mph I never seem to get the full 310.
  9. mociaf9
    mociaf9 Active Member
    And you're never going to because the "full 310" isn't "310 at all speeds, and in all conditions". ;) It's 310 miles when your usage is averaging 242 Wh/mi. You can look at your usage, if it's over 242 you'll be getting less than the rated miles. If it's under 242, you'll be getting more than the rated miles. When you'll get exactly 242 Wh/mi will depend on the weather, road conditions, elevation changes, what wheels and tires you have on the car, how inflated your tires are, etc, but it will pretty much never be at a speed as high as 75 mph unless you're going down a hill or have a very strong and sustained tail-wind.
    As for the supercharger...Nope, unfortunately no way to know. It could already be in construction without anyone knowing about it or it could still not be built for another 5 years. Best recommendation is to follow this thread--where any information will be posted if someone finds some--and to keep an eye on the map at supercharge.info.
  10. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Why would you ever expect to get 310 mile range at 75mph? You need to do a little reading about the effect of speed on range, and what EPA rated range means.
  11. Zella
    Zella New Member
    Amarillo
    I took ownership of my model 3 less than a month ago. Though I have watch many review videos there is still quite a bit of information that is learned through experience. I am not hating on my Tesla, I absolutely love my car, but this region of the State is pretty thin on charging options. From my house to the location a little south of Lubbock is 128 miles. Round trip would be 256-265 depending on driving in Lubbock. I generally stop charging at 279 miles but I can obviously bump that to the full 310 the night before a Lubbock trip. I assume weight, wind and speed are the main factors to considering actual range. Has anyone come up with formulas that data can be keyed into to get a rough estimate of range?
  12. Zaxxon
    Zaxxon Supporting Member
    Colorado
    Check out A Better Route Planner. Uses tons of actual real-world data and is very accurate if you set the parameters properly.
    To directly answer your question--speed, temp, wind, elevation changes, extra weight, tire pressure, wheels/tires, etc. All have an impact.
  13. reddy
    reddy Member
    Amarillo, TX
    Update :: No permits filed with City of Lubbock, and no new DIG TESS requests from Tesla around Lubbock as of today.
  14. timpierc
    timpierc Member
    Can you plug into a 120V wall outlet while you're in Lubbock? I'm assuming you're going down there for work, so if normal 8 hour work day, that'll get you ~ 40 miles back into the battery before heading home.
  15. Twiglett
    Twiglett Single pedal driver
    Austin
    Check out plugshare.com for local charging options, but for route planning I use either A Better Routeplanner or https://evtripping.com/ or EV Trip Planner depending on what I'm looking for
  16. Zella
    Zella New Member
    Amarillo
    My daughters are competitive cheerleaders for Ultimate Cheer out of Lubbock. I have been thinking about asking the gym owner if I can pay to have a destination charger installed at the gym. Not sure how all of that works though.
  17. Zaxxon
    Colorado
    If they shoot for the workplace charging program (Charging Partners), Tesla may offer the HPWC hardware for free. You'd just have to cover the installation costs. Especially in a city with such a relatively high population and low charger density, Tesla may be more willing to have them join.
    I took a work road trip to Lubbock from Colorado last summer in my 3, and at that point the only L2 in town other than at car dealers was at the Best Western--and they had exactly one. I had to call ahead and a hotel manager had an employee park in the spot to ensure I had access, or else I'd have been in trouble. Wound up working great.
  18. reddy
    reddy Member
    Amarillo, TX
  19. nwdiver
    nwdiver Well-Known Member
    United States
    Another TMC member was successful in something similar. Tesla paid for the equipment and Charlie paid for the installation. Since Tesla had previously paid for the install they even later refunded Charlie the cost of the install.
    Charging Partners
