HankLloydRight
No Roads
19 > 21
Seriously? Do you understand how the scientific method works? Those results prove absolutely nothing.
First of all, you're cherry picking your results by leaving out the .90g and .91g results on the 21" rims.
That analysis is the epitome of "apples and oranges."
Let's see, we have three different organizations running these tests, likely under very different scenarios (weather, track, temperature, drivers, g sensors, etc):
- Car and Driver
- Motortrend
- Edmunds
These tests were all done on NINE different cars, each with different weights, suspensions, RWD/AWD, production improvements (early Sig cars to P85Ds), Performance or Performance+ enhancements, and different drivers:
- 2012 P85
- 2013 P85
- 2013 P85 Sig
- 2014 nonP 60
- 2014 P85+
- 2015 nonP 70D
- 2015 P85D (Car and Driver)
- 2015 P85D (Motortrend)
- 2015 P85D (Edmunds)
Not to mention, absolutely no controls over tire pressures or other variables between any of these tests.
Now if ONE organization used ONE car for exhaustive tests, on the same day, with the same driver, using the same make/model tire on 19" and 21" rims with conclusive results, then you might have a case. Otherwise, this is, at best, a pedestrian data analysis.
