beeeerock
You know, I've seen the comment about extensions many times, so I have to assume it's based on some sort of reality. The off-axis change to lever length was always my assumption. But I wonder if there is a dynamic effect in here somewhere, relating to how the extension 'winds up' and then releases when the bolt or nut finally breaks through static friction to kinetic friction. Maybe there is a bit of 'impact wrench' effect in this?Doesn't matter how much the extension twists the torque is the same. Is no different than how much the springs in your suspension are compressed, the spring compression does not lessen or increase the load carried by the wheels.
It might mean slightly more torque applied, but I can't see it being anywhere near enough to be a concern. Up until a few years ago, my rules for lug nuts were 'tighten a little at a time, across the star', 'tighten enough that they won't fall off' and 'leave them loose enough that the tire iron in the trunk will be enough to remove them!'. The last one was learned the hard way in the bush, after a tire shop torqued those babies on so tight that I rounded out my lug nut wrench trying to change a flat... not a great day, that one!!! :tongue:
