Lugnuts - will these fit?
Discussion in 'Model S: Interior & Exterior' started by mnx, Aug 28, 2013.
  1. mnx
    mnx 2013 P85
    Ancaster, Canada
  2. FlasherZ
    They're the right size... they appear to be nearly the same as those splined ones from the 19" wheel post. That said, as noted in later posts here:
    19 Turbine Wheel Solution - Page 7
    19 Turbine Wheel Solution - Page 9
    ...that other wheels may not work with these narrow lug nuts, you may need larger lug nuts; for example, the post suggests that the OEM wheels could likely not use those. Make sure they can take the full torque spec of the Tesla (129 ft lbs).
